  • SN95 4.6L Mustang Tech
sct xcal 2 question
  • Thread starter Thread starter 03s281sc
  • Start date Start date Nov 16, 2006
03s281sc
245
maryland
Nov 16, 2006
  • Nov 16, 2006
the instructions say to remove the fuel pump and electric fan fuses...is this neccesary and if so what fuses are they....
KidCapri50
40
  • Nov 16, 2006
There should be a fuse box on the left under the hood and a index under the lid.
BTW-What part of md?
03s281sc
245
maryland
Nov 16, 2006
  • Nov 16, 2006
yeah i know where the fuse box is, i was just wondering if the fuel pump and fans are labeled, i havent looked yet b/c of the rain n now it's dark out...but im in pasadena, northern aa county
96BlueStangGT
38
Southern Indiana
Nov 16, 2006
  • Nov 16, 2006
There's a picture in the owner's manual for your car. On my car, it's #20 &#60. There might be multiple numbers though. You are supposed to remove them because when it is downloading the file, the fan and pump run, which wears the battery down. I did it once without pulling the fuses before with no problems though. I usually pull them just to be safe.
Mossberg
ATL, Shawty
Nov 16, 2006
  • Nov 16, 2006
I never pull my fuses when I install a tune. My battery works well though.
the98stang
2,408
Clovis, CA
Nov 17, 2006
  • Nov 17, 2006
Better safe than sorry. Take a whole 3 seconds to pull them out.
spederman
732
  • Nov 17, 2006
I was pulling those 2 fuses when i first started messing with my XCAL. For some reason the fan and fuel pump click on as soon as you plug in the XCAL. I think they say to do that because if you have a weak battery and it dies during a download, i bet you;ll be in a world of hurt. But since i know what i'm doing with it, i just get in and do what i need to and get out of it and my battery has been fine. IF you are playing around with it, you might want to pull the fuses so it doesnt drain your battery.
BooWFO
991
Louisville, KY
Nov 17, 2006
  • Nov 17, 2006
I never pull the fuses and I flash to a different tune prolly 2 or 3 times a week average.
It is the battery don't die while your doing it.
R
Rocketman
730
SoCal
Nov 17, 2006
  • Nov 17, 2006
You don't need to pull the fuses.
You'll be fine.
I've flashed mine dozens of times and have never had a problem.
the98stang
2,408
Clovis, CA
Nov 17, 2006
#10
  • Nov 17, 2006
  • #10
Seriosuly, it takes 2 seconds to pull the fuses. If the battery dies or you loose power for some reason while flashing, you are going to have TONS of trouble. Why take the risk when you can literally pull the fuses in a few seconds?
Do what you guys want, but I'm not lazy
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
