Has anybody ever blocked off the bottom of the engine compartment to keep dirt and mud off of the engine? I did this partially on a car one time and it really kept the engine clean. I wonder if it could be completely blocked off without overheating? I'm sure the engine would stay cool enough with a good cooling system, but then I think about the heat from the headers?
Are you mud bogin that thing is that the problem? I actually think the louvers facing toward the rear of the car would work. The air that flow in from the radiator would get pulled through them I think. The heat from the exhaust may be too much and then where are you going to get cold air from? Actually on second thought I dont think it is a good idea. you may reduce the airflow too much and not have enough through your radiator. hmmm i am going to have to think about this more.... need to think back to my aerodynamics class
