seat track assembly
  • Thread starter Thread starter Haus
  • Start date Start date Nov 2, 2009
H
Haus
408
  • Nov 2, 2009
On my 92 5.0 the metal bracket that connects the seat track to the floor broke and i want replace it. what years should i look for at the junk yard?
manual seats
Mustang5L5
Mod Dude
Feb 18, 2001
43,327
18,051
224
Massachusetts
Nov 2, 2009
  • Nov 2, 2009
Non power? pretyy much any fox track should work
H
Haus
408
  • Dec 16, 2009
The front left seat bolt ended up breaking out of the floor board
Adams91LX
689
12
29
Plano, TX
Dec 16, 2009
  • Dec 16, 2009
i've had 3 foxes... all 3 have had driver's front left bolt broken out of floor board... and i have had one seat track crack...
any fox will work...
H
Haus
408
  • Dec 21, 2009
This is a PITA. is there Fix for this broken floor board so i can bolt back in my seat.
i think im just gonna either switch seats. put the passenger seat in the driver seat spot. I still have to get another seat track. This way for the time being ill have 3 of the bolts bolted down instead of just the two that were actually supporting the seat.
1990 HOSS
53
Carnesville, Ga.
Dec 21, 2009
  • Dec 21, 2009
Take it to a good welder. My front left seat bolt had ripped out of the floorboard too and there was about 3 square inches of metal still attached around the bolt. I took it to a local, experienced welder and he bent it back into place and welded it. Fixed it right up. No problems since...knock on wood. You definetly want all four bolts in and holding to distribute the forces evenly or you're gonna end up with more damage.
apollo12
155
port st.lucie fla
Dec 22, 2009
  • Dec 22, 2009
in the past I have done some welding to the stock brackets for added support, as stated above most fox body brackets will work.I would suggest you sanding and painting the brackets so they last
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Monday at 8:23 PM
Fox 5.0 Mustang Tech Tuesday at 8:35 PM
rednotch
M
WTB Seat track
  • Magnet86
  • Jan 15, 2026
  • Want to Buy
Want to Buy Jan 19, 2026
Magnet86
M
L
2012 Seats in 98 GT Convertible - pictures coming
  • lparsons42
  • Aug 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2025
lparsons42
L
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
