  • 1994 - 1995 Specific Tech
Secondary Fuel Pump
  • Thread starter Thread starter Guero
  • Start date Start date Jun 6, 2008
Guero
2,148
Jun 6, 2008
  • Jun 6, 2008
The Fox came with a secondary fuel pump for the S/C.. but it has a stock pump... If I install a 255 can I remove the secondary pump? It will be less things 2 worry bout if it breaks of something
T
turbogt
723
Montana
Jun 7, 2008
  • Jun 7, 2008
I would keep the t-rex... With the T rex and a 255 you should be good to around 600 horse.. That way if one DOES go bad, the other will should keep you running..
Guero
2,148
Jun 7, 2008
  • Jun 7, 2008
I dont plan on pushing 600hp.... Im only gonna do Bolt-ons and 12lbs of boost....Do I need it?
Stanger007
2,015
Baton Rouge, LA
Jun 7, 2008
  • Jun 7, 2008
Did you say you were keeping the iron heads?
If so then the 255HP will be fine for you. Any more and the T-rex becomes very helpful.
My personal car topped out a NON HP 255 around 380rwhp-ish. I added the TREX and the pressure is solid now.
To know for sure, find a way to log your fuel pressure at the rail and watch it alongside the boost. Most tuners will do this for you on the dyno (hint, hint).
Wes
T
turbogt
723
Montana
Jun 7, 2008
  • Jun 7, 2008
up to 600.. If you already have one, why are you so afraid of using it? I truly like the idea of twin pumps..
Stanger007
2,015
Baton Rouge, LA
Jun 7, 2008
  • Jun 7, 2008
The only reason I might consider NOT using it in his case is because of the heat where he lives and the recirculation heat/pressure that builds up.
But I am also on the side of the fence that says I'd rather have too much fuel than not enough.
Wes
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
