  • SN95 4.6L Mustang Tech
Self-installing Cams
  • Thread starter Thread starter BlackenedSVT
  • Start date Start date Jun 1, 2007
BlackenedSVT
1,841
New Jersey
Jun 1, 2007
  • Jun 1, 2007
Hey there guys. I have a dyno date in july with JDM engineering here in new jersey so i'd like to add CAMS to my list of mods before i go down there to get a tune. I'm leaning towards VT Stage 1 Cams, can someone suggest maybe some other alternatives that they'd had good experiences with??
Also, do you think using the stock valve springs is good enough with the stage 1 cams? Or would i see more HP out of swapping in new springs too?
Also, i can't seem to find the write ups on the self-cam installs. I'll be installing the cams myself to save myself the like $1500 the shop wanted to install them.
BlackenedSVT
1,841
New Jersey
Jun 2, 2007
  • Jun 2, 2007
bump
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jun 2, 2007
  • Jun 2, 2007
If this video is still up, it might give a good idea of the effort involved. PM Christie if you have questions.
http://forums.stangnet.com/showthread.php?t=628019
BCB00GT
420
Jun 2, 2007
  • Jun 2, 2007
This is probably one of the best step by step write-ups I have seen. Especially if you have a 99-00GT and need to replace cam gear, regardless if you are changing springs.
http://www.*.com/?show=articlesdet&aid=39
* = m o d u l a r d e p o t
BCB00GT
420
Jun 2, 2007
  • Jun 2, 2007
This is a very basic summary (thanks silverbullet) for 99-00GT:
1. Set the motor to TDC (there is a notch on the crank pulley that lines up with a mark on the timing cover), take of the valve covers, take off the timing cover and mark your timing marks on both chains at the crank and at the timing gears.
2. Unbolt the tensioners and chain guides, remove the timing chains.
3. Unbolt the cam in the same center-out pattern you would use if you were tightening the caps; you want to loosen them only a little bit at a time, going in order. This is good insurance to make sure you dont stretch the cam caps. BEFORE removing any cam caps, mark them with a sharpie or something because they have to go back in the same location and orientation.
4. Once the cam caps are off, remove the cam and keep the followers in order, as well as the lash adjusters. When you put the lash adjusters back in you will have to bleed them to get the followers back on. to do this, you compress them in a vise to squeeze the oil out of them. This will make them springy instead of solid.
5. Bolt the cams into place (torqued in order), install the chains, guides, and tensioners, and then you install the compressed lash adjusters.
6. Slide the follower in behind the lobe, and snap it into place using a flat head screw driver.
7. Install cam gears, crank gear and set timing marks. Verify install.
8. Reassemble.
Some other good threads with info:
http://forums.stangnet.com/showthread.php?t=701763
Another install option:
http://forums.stangnet.com/showthread.php?t=566683&highlight=cam+install
BlackenedSVT
1,841
New Jersey
Jun 2, 2007
  • Jun 2, 2007
thanks guys
BCBOOGT that 1st post of yours, the link doesn't work
BCB00GT
420
Jun 2, 2007
  • Jun 2, 2007
SteedaGTJ22 said:
thanks guys
Replace the "*" with "m-o-d-u-l-a-r-d-e-p-o-t" without the "-"
BlackenedSVT
1,841
New Jersey
Jun 3, 2007
  • Jun 3, 2007
anyone have cam recommendations? i know the VT cams drop torgue to gain high end HP. how about comp cams?
hotmustang331
2,967
Bastrop,TX
Jun 3, 2007
  • Jun 3, 2007
Mine made 308RWTQ with the VT cams...not too bad IMO. And my car ALWAYS seemed down on torque from the get go, and never put down good #s. Once I got the cams that changed everthing around...DEFINATLY get them.
And yes valve springs WILL net you a bit more power due to better valve control. And now that im having valve float issues with mine (turbo back pressure causing weak springs to float) I wish we would have put valve springs in it when we had everything down.
BlackenedSVT
1,841
New Jersey
Jun 3, 2007
#10
  • Jun 3, 2007
  • #10
any valve spring recommendations to be paired with the VT Stage 1 cams i'll be ordering soon?
Is there really any differences in springs?
blown4_6
35
PA
Jun 4, 2007
#11
  • Jun 4, 2007
  • #11
The seat pressures are different on the springs. Im running comp cams (102300PT#) which is 236 / 240 @ .500 lift and also put in the comp springs while I was at it. If you do this yourself MAKE SURE YOU COMPRESS THE LIFTERS ALL THE WAY before reassembly, I didn't compress them fully and think I bent a valve on start up. Anderson motorsports also has a tool so you dont have to pull the timing cover off the front of the motor. Its well worth the $20, you will need someone there with you to hold the tool though. I used it the second time I took it apart and saved about 2 to 3 hours.
jivepepper
776
Under a Sombrero. in WV.
Jun 5, 2007
#12
  • Jun 5, 2007
  • #12
I just dropped my HP 292s cams in with the AFM Cam Retention tool. Took one lazy afternoon. I then drove 200 miles to the tuners.
BlackenedSVT
1,841
New Jersey
Jun 6, 2007
#13
  • Jun 6, 2007
  • #13
was it a pain putting the chains back on with that timing cover still on?
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Jun 6, 2007
#14
  • Jun 6, 2007
  • #14
I bought the Anderson Motorsports tool when we did our swap, that thing was IMO the biggest pile of crap I've ever seen. C-Clamp and Vice Grips worked 10x better. You'd have to talk to someone who had to use different cam gears about the chains, I got to reuse my cam gears so we didn't have to mess with the chains. I have a link in my sig for the PI cam swap I did, it should be very similar to doing any other cam swap (except we didn't degree them).
BCB00GT
420
Jun 6, 2007
#15
  • Jun 6, 2007
  • #15
I think the thread starter has a 2002 GT so no new cam gears are needed. Should be able to do what you did provided not changing springs.
Dusstbuster
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Jun 6, 2007
#16
  • Jun 6, 2007
  • #16
I wasn't sure if VT or Comp cams required new sprockets or not.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jun 6, 2007
#17
  • Jun 6, 2007
  • #17
$1500? I'd get a new installer
BlackenedSVT
1,841
New Jersey
Jun 6, 2007
#18
  • Jun 6, 2007
  • #18
thats not that far off of a standar going price from what i hear, and as i've stated in the 1st thread, i'll be doing this myself...
blown4_6
35
PA
Jun 8, 2007
#19
  • Jun 8, 2007
  • #19
Its not hard to put the chains on at all with help from someone. Just put the gear on the chain then slide it on the cam.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Friday at 6:22 PM
JH96GT
