sensors effecting poor "hot start" condition?
Phatt_daddy said:
This sounds alot like what mine is doing. Only mine is/ was flooding out until I replaced my map sensor. The car still has a tough time starting when I shut it off and try to restart it. Sometimes I have to let it sit until it cools bnack off.
When I turn the key it will spin like it is out of time but never fire off (btw I have timing set to like 12-14 btdc). I also still have a prob with gas fouling plugs when it does this. Sorry to just jump on the thread but I figured if they can help you why not kill two birds with one stone.
Nate
Yep, that is what happens when you stick to big on injectors for a combo without a tune like me. The 30lbers. Mine does the same thing, to the "T".
jaymac said:
so THAT'S why you have 12 billion posts...
CHEATER :uzi:
j/k
that does suck, though...
Yeah, it kinda does. Joe is right - my brain does not even function (using the term loosely) till late at night and then I can't shut it down (bad circadian rhythm too).
:sleep:
Phatt_daddy said:
Just one problem 5spd GT....... My car still has the stock (I think.they are off white and yellow) injectors, no wild cam (if other that stock), just a simple 4.040 bore size. So any other suggestions?
Nate
Yes, those are stock injectors. So you have a 308?
Do you have longtube headers? They will heatsoak your starter and cause hot-start problems...just a suggestion. :shrug:
Good Luck
