  • Mustang Sound & Shine All
sequential taillights
  • Thread starter Thread starter geoff_is_cool
  • Start date Start date Sep 13, 2004
G
geoff_is_cool
24
  • Sep 13, 2004
i bought some sequential talilights and installing them wasnt so bad...except the middle bulb does not light up. the instructions say this this is probably because of the connection or there is something in the way of the connector (dirt...)whats the best way to clean out the hole, its pretty small?
Mystifier
24
Lynnwood, WA
Sep 13, 2004
  • Sep 13, 2004
Use some isoprophyl alcohol and a small hobby paint brush or tooth brush to clean electrical connectors.
N
n0v8or
604
Rhode Island
Sep 14, 2004
  • Sep 14, 2004
Which brand did you buy? Some require a connector pin to be added to one of the sockets. If not fully seated, that position will not light. Do you have the identical problem on both the left and right sides?
G
geoff_is_cool
24
  • Sep 14, 2004
i'm not sure what brand it is but it does require the adaptor to be put in on both sides and i am having the same problem on both sides. i'm sure the problem is that its not a good connection but i'm not sure how to make it better, i put it in as far as i could, but its still not working.
N
n0v8or
604
Rhode Island
Sep 15, 2004
  • Sep 15, 2004
OK . . . here's the solution I used when I had a similar problem. The extra contact pin added to the lamp socket would not make relaible connection on one side.
I went to a wrecking yard . . . there were lots of Mustangs there . . . and bought a complete smashed taillight assembly from a '98 (same lamp configuration as my '03) for $5. Only the lens was broken; all of the sockets and bulbs were good. I removed the turn signal sockets (in less than a minute) and used them.
GTPhreak
5,505
Rowlett, TEXAS
Sep 16, 2004
  • Sep 16, 2004
also check to make sure you have dual filament 3157 bulbs in there and not just single filament bulbs
M
Resolved 2010 V6 Taillights wiring issue
  • MRMRacing
  • Dec 7, 2024
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Dec 8, 2024
MRMRacing
M
M
Another Newbie
  • markb
  • Dec 1, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 7, 2025
markb
M
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Need some help with LED conversion on 04 GT
  • FATTS_DC
  • Feb 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 24, 2025
stormsedge
