  • SN95 4.6L Mustang Tech
Serpentine belt problem
  • Thread starter Thread starter lonestar1
  • Start date Start date Jul 22, 2006
L
lonestar1
49
Houston, Texas
Jul 22, 2006
  • Jul 22, 2006
Gentlemen, I decided to replace the serpentine belt on a 2002 GT. Got the old one off and am having a big problem getting the new one back on. Obviously I'm missing something to get enough slack for all the pulleys.
Need some expert advice.
Also got a new pvc valve and cannot find where it goes. I'm getting old!
Thanks in advance,
Lonestar1
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 22, 2006
  • Jul 22, 2006
Put a long breaker bar with a 3/8 inch drive into the 3/8 inch hole on the spring loaded tensioner idler pulley assembly. This makes it easy.
Here is a link: http://www.bullittarchive.com/1004.htm
94GTHO
200
Richmond, Va
Jul 22, 2006
  • Jul 22, 2006
howd you get the old one off?
DTNODYA
831
  • Jul 22, 2006
One time I was having a hard time getting a belt on my car and the belt was snagging on one of the lower pulleys so before you get super frustrated, make sure that the belt isn't getting 'caught' somewhere.
That probably sounds relatively stupid but if you have ever had this happen, you know what I mean.
PCV goes on the valve cover towards the back. Follow the rubber hose from the front of the plentum if it helps.
L
lonestar1
49
Houston, Texas
Jul 22, 2006
  • Jul 22, 2006
Gentlemen, took off one of the followers to get the old one off. Is the pcv valve on the drivers or passengers side and is just a plug in? I took off the tensioner and it wont budge that way. I guess I'll have to put it back on to get it too release.
thanks for the help
Lonestar1
SigmaPride
170
  • Jul 23, 2006
Your belt probably routes like this: http://www.bullittarchive.com/1015.htm. You don't need to take anything off, just make sure you have it routed correctly. Just use a socket wrench in the 3/8" drive hole on the tensioner to move it. It should move rather easily.
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 23, 2006
  • Jul 23, 2006
It's 1/2 inch
L
lonestar1
49
Houston, Texas
Jul 23, 2006
  • Jul 23, 2006
Belt and PCV
Gentlemen, got the belt on in about 30 seconds now that I figured out the tensioner. Thanks!
I must have gotten the wrong pcv valve. I see a breather hose from the top of each valve cover with what looks like pcv valves, not the 2 small hose one I got from the parts place. Looks like they have plastic clips on them. Don't want to break the clips if these aren't what I should be changing. Any help would be greatly appreciated.
Lonestar1
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 23, 2006
  • Jul 23, 2006
tomustang said:
It's 1/2 inch
Mine is 3/8, just double checked it
d98gt
4,505
59
204
SE Texas
Jul 23, 2006
#10
  • Jul 23, 2006
  • #10
1/2" for me also
Anyway possible to take a picture of the PCV that they sold you?
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Jul 23, 2006
#11
  • Jul 23, 2006
  • #11
3/8" tensioner here too.
The PCV valve is on the passanger side underneath the intake boot. You'll have to pull the hose off (the previously mentioned one that comes from plenum) before you can take the valve out. Once you get to that point you should be able to twist it out (1/4-1/2 turn counter-clockwise if I remember right). Reverse procedure to install...
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 23, 2006
#12
  • Jul 23, 2006
  • #12
weirdness..
SigmaPride
170
#13
  • Jul 24, 2006
  • #13
I think 2000 up is 3/8". My '99 is 1/2" and pretty sure buddy's 00 was 3/8".
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 24, 2006
#14
  • Jul 24, 2006
  • #14
maybe a poll is in effect...
R
RochesterGT
52
Penfield, NY
Jul 24, 2006
#15
  • Jul 24, 2006
  • #15
tomustang said:
It's 1/2 inch
My '00 is a 3/8".
d98gt
4,505
59
204
SE Texas
Jul 24, 2006
#16
  • Jul 24, 2006
  • #16
That's the first time that I heard of the tensioner size being changed. That's good info to know
I know the 98s have 1/2
  • Gulftown980x
  • Jul 29, 2026
squeak93
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • brandyn200
  • Jun 20, 2026
AeroCoupe
