setting fuel pres.????
  • Thread starter Thread starter lib88stang
  • Start date Start date Aug 24, 2004
lib88stang
154
Pa
Aug 24, 2004
  • Aug 24, 2004
what is the correst way to set the fuel pres.? And what should I set it at??
Do I set it with car at idle with the vac. hose on or off the reg.???
blk92stangg
583
Hawaii
Aug 24, 2004
  • Aug 24, 2004
Vac off the reg, and set it to stock psi. Then fool around with it to see how it runs at WOT. I would not go below stock tho.
lib88stang
154
Pa
Aug 24, 2004
  • Aug 24, 2004
well what is stock??
T
TheUser
1,859
Springfield, MO
Aug 24, 2004
  • Aug 24, 2004
I believe stock is 38 psi vac off
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 24, 2004
  • Aug 24, 2004
Use the SOP meter...
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have you buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in. Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
M
mayer5oh
12
quakertown, pa
Aug 24, 2004
  • Aug 24, 2004
thats kinda funny, when i want to time my car, instead of goin to the track, i just find a nice stretch of pavement and have my friend count one mississippi... 2 mississippi... 3... if you have a really smart friend he'ell even get your 60', 1/8 mile...
justtttttttttt kidding
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
