I cant seem to locate an inch pound torque wrench that measures low enough to set the preload, all the ones that I can get locally start at 30 inch pounds and most start above 100.has any one set their preload without using a torque wrench. I have the sleeve crushed down to the point where there is the slightest bit of play and im thinkin of just going on with the rest of the setup.Im gonna check the backlash and also check the pattern with the marking compound.
