  • 1994 - 1995 Specific Tech
shaking on take off
  • Thread starter Thread starter belzebub2u
  • Start date Start date Nov 16, 2004
belzebub2u
164
Woodstock GA
Nov 16, 2004
  • Nov 16, 2004
hey guys, question. when im taking off in 1st as im letting out the clutch the whole car starts shaking really bad. the only way to keep it from happening is to either LAUNCH! or feather the clutch, get the car rolling, feather/roll once the car gets goin about 5mph i can let it out all the way. if i start off in second gear it does not do it. this has just started happening today and im wondering what it could be. i just installed 3.55's last week i have a pretty much stock 5.0 with a 5speed. was wondering if it would be the clutch, trans, or rear end. if the car is rolling, it doesnt do it at all. i also have a busted transmission mount (came that way with the car gonna fix it when i fix the rear main seal)
Joe 5.0
1,184
Macomb, MI (metro detroit)
Nov 16, 2004
  • Nov 16, 2004
What kind of clutch do you have? It could be clutch chatter, but if you have a broken mount that could cause some driveline vibs too.
belzebub2u
164
Woodstock GA
Nov 16, 2004
  • Nov 16, 2004
no idea on clutch
all i know with the clutch is its fairly hard to push so im kinda thinkin it is a more race inspired clutch. sometimes the vibration is so bad i think im gonna break something, and i can hear that broken trans mount hitting down.
WHITE94COBRA
816
HUNTINGTON BEACH
Nov 16, 2004
  • Nov 16, 2004
That sounds like clutch chatter, my car also does that, I'm going with a custom built clutch for my car (my company does trade outs with a company that makes clutches) The clutch that is in the car just sucks. Also check your quadrant and make sure its not broken or bending if it is you will have a different release point each time making it harder to get a feel for your clutch and thus creating clutch drag. Is it hard to get into gear sometimes, mainly first from a dead stop? If so check it for proper cable tension and drag. Hope this helps a little.
H
HazMat404
1,749
Nov 17, 2004
  • Nov 17, 2004
when you drive the car, do you kinda tend to have the foot just touching the clutch in case you need it?? if so, you are makin the clutch touch just a tiny tiny bit and could be putting a glaze over the flywheel. if you tend to do that, drop the clutch once or twice from a higher rpm to knock all that glaze loose. happened to me cause i keep my foot on/right next to the clutch and find myself just barely touching it sometimes. worked like a charm for me but thats just a guess for yours
Joes95GT
3,132
Delaware
Nov 17, 2004
  • Nov 17, 2004
That shaking on take off, if what you are describing is like a vibration in the driveline that shakes a whole car until the clutch is released is a warped flywheel. Does it only vibrate while you are slipping the clutch out driving normally? As soon as the clutch is engaged completely (or almost completely), does it go away immediately?
If so, you have a warped flywheel.
Joe
Black70Fastback
319
Dyer, IN
Nov 17, 2004
  • Nov 17, 2004
well the friction disk is more likely warped than the flywheel but until you fix the trans mount you're just pissin in the wind.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
