Shift Kit
  • Thread starter Thread starter Fireman255
  • Start date Start date Jun 6, 2005
F
Fireman255
119
  • Jun 6, 2005
What shift kit should I get for my 66 C-4?
Is this complicated to install?
jerry S
1,365
52.22N 5.12E
Jun 7, 2005
  • Jun 7, 2005
B&M is the standard. What you want depends on your needs. the shift improver kit is entry level and costs about $30. It can be installed in about an hour. Next up is the transpak for about $50. It might take the same or a little more time to install. The installation can be done by anyone with a set of hand tools.
geostang351
946
Danb., CT
Jun 7, 2005
  • Jun 7, 2005
Make sure you have a big pan to catch all that messy fluid!
F
Fireman255
119
  • Jun 8, 2005
Sounds easy
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jun 8, 2005
  • Jun 8, 2005
A couple of cautions: use jack stands!, be very careful when messing with the valve body not to let the check balls drop out ( they're very hard to find out where they go back). You won't need much more than a ratchet, extension,socket, and drill. The ones I have done came with detailed instructions. If it doesn't come with a new filter, buy one and replace it at the same time. If money allows, it is also a good time to go with an aftermarket aluminum pan w/built in drain plug.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
