Shift light help
  • Thread starter Thread starter cobra2798
  • Start date Start date Jan 4, 2007
cobra2798
303
Clermont, Florida
Jan 4, 2007
  • Jan 4, 2007
I just installed my autometer monster tach. Everything works but my shift light dont go on. I think I have it wired right.
Power- radio fuse
light- headlight fuse
tach- coil
ground-ground
Thats how I wired it. I set the shift light at a couple of different RPM's and I get nothing. Can I wire it a differnt way to get it to work or is my shift light defective?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 4, 2007
  • Jan 4, 2007
is the shift light pluged in to the back of the tach....is it a pill type shiftlight....does it flash when you first turn on the ignition
cobra2798
303
Clermont, Florida
Jan 5, 2007
  • Jan 5, 2007
Found the problem. Where the shiftlight clips into the tach there is 2 little fuses in the clip and one was not seated in the clip all the way. I snapped it all the way in and it now works. Thanks anyway.
Dr. Wu 2000
554
Eastern, Pa.
Jan 5, 2007
  • Jan 5, 2007
I am wondering if mine is installed corectly...when I set the rpm it does not flash but when I am driving and get to the set rpm the light flashes The tach/shiftlight on my 04' cobra would flash whenever you first set your shift rpm point.
cobra2798
303
Clermont, Florida
Jan 5, 2007
  • Jan 5, 2007
Mine didnt flash when I set it, it flashes when you start the car and when you get to the set shift point.
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
