  • 2005 - 2009 Specific Tech
Shifting to Reverse
  • Thread starter Thread starter Pliskin
  • Start date Start date Jun 4, 2007
Pliskin
109
  • Jun 4, 2007
Hey all. I was having trouble going from 1st to reverse. Hell, maybe to reverse in general. Well I took it to the dealer and they said its nothing wrong I have to actually put it into 3rd or 4th first then into reverse for the synchros to reset or something. Is this happening for everyone?
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 4, 2007
  • Jun 4, 2007
i usually put it in 2nd, then reverse. works well for me.
07gtfolife
125
  • Jun 5, 2007
Same thing happens to me, I thought I was the only one this was happening to.
LV51FER
318
Caerphilly, Wales, UK
Jun 5, 2007
  • Jun 5, 2007
Same here. If it won't go into reverse, let the clutch out in neutral and then depress the clutch and go again. If it's any consolation, it's exactly the same on my Mazda 5. Must be a Ford trait....
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Jun 5, 2007
  • Jun 5, 2007
My '00 GT was the same way as far as being hesitant going into reverse... I too would have to put it in 3rd then reverse. There isn't anything "wrong" with your tranny, just it's trait...
Pliskin
109
  • Jun 5, 2007
Yeah I usually just let out the clutch and put it back in....works. I just wanted to see if the dealer was ing me.
McQueens Dream
260
Winston Salem, NC
Jun 5, 2007
  • Jun 5, 2007
well, they probably are BSing you some, but i have had this same issue in every 5 speed mustang i have owned now, and i have had 5 of them. not a big deal, you just don't think it should have to be that way...
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 8, 2007
  • Jun 8, 2007
reverse has no synchros which is why it always goes in easier after going into any other gear. there isnt anything wrong with the tranny. it has been like that in nearly every manual car i have driven, not just fords.
Pliskin
109
  • Jun 8, 2007
I was testing it out today and they were right, I cant go from 5th to R. Of course I like that, but I CAN go in from any other gear I tried (specifically 1st). Its just that some times I cant shift from 1st to R some times I can. The manual for our cars says the following:
The gershift lever can only be moved into R (Reverse) by moving it from left of 3 (Third) and 4 (Fourth) before shifting into R (Reverse). This is a lockout feature that protects the transmission from accidentally being shifted into R (Reverse) from 5 (Overdrive).
What I get from that is "left of 3 (Third)" includes 1st...doesnt it?
bigcat
May 1, 2005
3,015
7200 feet
Jun 9, 2007
#10
  • Jun 9, 2007
  • #10
yes
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
