What does everyone think of the new SHM 6.0L aluminum blocks? It says that they are capable of 2500 HP!!! go to http://www.seanhylandmotorsport.com/
to check out the pictures, its on their home page! Here is what the stats say:
Sean Hyland Motorsport are proud to announce the release of the 5.4 and 4.6 aluminum motorsport engine block. These blocks have taken a year to design, and incorporate features designed to provide durability and increased performance.
The 5.4 block can be ordered with a bore size of up to 3.75", which results in a 6 liter all aluminum engine for your Lightning, Mustang or rod project. The aluminum motorsport blocks benefit from many design features listed below. Order yours today for early 2004 delivery.
Sean Hyland 4.6/5.4 Motorsport Blocks
356T-7 aluminum alloy
lightweight, only 95lbs for the 5.4, 88lbs for the 4.6
smooth, deep skirt construction
billet steel main caps, main studs supplied, optional aluminum main caps
13mm thick deck
External oil drain backs reduce windage losses
cast iron sleeve, 3.55-3.75 bore
Block designed for semi-stressed mid engine applications
2500hp capable
4.6 Motorsport Block $3995
5.4 Motorsport Block $4495
13mm thick deck
2500hp capable
