  • SN95 4.6L Mustang Tech
Short throw shifter install
  • Thread starter Thread starter MrGame
  • Start date Start date Dec 3, 2006
MrGame
52
  • Dec 3, 2006
I'm going to order a steeda tri-ax shifter, and I'm going to do the install myself. it seems pretty straightforward, but I have limited experience working on cars. What are some things i should watch out for?
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Dec 3, 2006
  • Dec 3, 2006
It's not tough...pretty easy to do really. Just make sure you transfer the plastic cup on the shifter ball over to the new shifter.
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Dec 3, 2006
  • Dec 3, 2006
And don't put in the shift stops (double check with Tremecs recomendations)
four six
506
Hobart, IN
Dec 3, 2006
  • Dec 3, 2006
Its easy. BTW get a MGW
mustangkid05
199
  • Dec 3, 2006
is a short throw worth the money?
four six
506
Hobart, IN
Dec 3, 2006
  • Dec 3, 2006
yeah, just about anything is better than stock
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Dec 3, 2006
  • Dec 3, 2006
Oh hell yes. It's a HUGE difference
BTW.... MGW shifter > *
mustangkid05
199
  • Dec 3, 2006
dont want to throw the thread off but if i buy an mgw for a t-45 do i have to put them shift stops in??
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Dec 3, 2006
  • Dec 3, 2006
Unsure, but the MGW directions will tell you if they do or not. Mine for my 3650 told me not to even though i knew this beforehand
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 3, 2006
#10
  • Dec 3, 2006
  • #10
I have a T-45 and it suggests that you do.
The install is one of the easiest mods you an do yourself. Minimal tools and it makes a huge difference. I have the Tri-ax and has been good to me but I've heard good things about the MGW piece. In fact I have the MGW handle on my Tri-ax
sgarlic
3,085
Dec 3, 2006
#11
  • Dec 3, 2006
  • #11
My advice is just like said above, get an MGW instead of the loud triax, be careful when removing the old shifter (rock it back and forth to remove it, don't hammer it) .. when installing the new one, use plnety of RTV around the base of the trans where the shifter mounts to (gasket not required, mines quiet as hell with just RTV,) and like they said above, make sure to take that plastic cup piece off the old shifter and put it on to the new one. No shift stops.
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Dec 3, 2006
#12
  • Dec 3, 2006
  • #12
Both the MGW and the tri-ax are great shifters...but i went MGW simply because it was rumored to be silent.
And it is. There is ZERO noise from my shifter. You would think it was the stock shifter.
I had to make an insert to use my Mach 1 shift knob however. I just cut a 1/4" stud of a M12x1.75 bolt, cut a slot in it and used a screwdriver to adjust the hieght of the knob.
BurningRubber
1,865
24
58
Dec 3, 2006
#13
  • Dec 3, 2006
  • #13
If you can use a socket wrench, and squeeze a tube you can install a shifter.
Tim2002GT
635
Tulsa, Oklahoma
Dec 3, 2006
#14
  • Dec 3, 2006
  • #14
A 6 inch socket extension will help things go alot smoother for ya!
twogts4us
4,188
12
79
Dunedin, FL
Dec 3, 2006
#15
  • Dec 3, 2006
  • #15
http://www.stangshiftergaskets.com/ - best $6 bucks you'll ever spend.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 3, 2006
#16
  • Dec 3, 2006
  • #16
The noise never bothers me...
Duke309
90
Orlando, FL
Dec 3, 2006
#17
  • Dec 3, 2006
  • #17
I agree with this, the gaskets are very nice. Dunno if it actually reduced noise, as i have never used rtv with my mgw, but it is so much easier.
MrGame
52
#18
  • Dec 3, 2006
  • #18
i'm going to order the MGW, and i ordered the gasket. How long did the gasket take to get to you?
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
  • Gulftown980x
  • Jul 29, 2026
squeak93
