the buggest help like said is it helps you nail the 2-3 upshift fast and almost every time. as to which one to buy is up to you. if possible find people you know that have aftermarket shifters so you can feel them and see which ones you like.
Has anyone test driven an '05 GT 5 speed? OMFG those are the worst stock shifters I have ever used. I thought I was gonna pull the shifter off, it was so flimsy and sloppy. And the clutch was the WORST!!
No but while we are on this topic, I can't STAND how those crappy shifters look. They look too luxury style-ish, like they belong in a G35 or something. I HATE that its a straight up and down shifter, with a dinky little kob covered in a box shifter boot. the 94-04 models have my favorite shifter style, where the shifter isn't 2" big and curves towards the driver (...well my aftermarket shifter doesn't anymore)
And while I haven't driven, nor sat in one myself, I heard the clutch was the same as all the other GTs
What trans do they use? The T-3650 right?
In all reality probably not, it should 'feel' better and inspire more confidence and reduce the number of mistakes but the gear box will only change gear as quick as you move the gear stick.
If you are powershifting then it should be easier with less risk of damaging the linkage mech.
At best look at around .1 of second improvement, its more the consistancy of ET's that you should now be able to get with more ease.
