Ok i just did that ac inverter install right well i got the power and ground mixed up when i connected them into the cig lighter. So when i put power on my car and turned it on i heard a click from the engine and that was it. I take it out of run and or pull the key out i here a clicking under the dash near the fuse box. I checks the fuses inside the car have abitch of a time check the ones in the Engine. What did i blow what do i need to do to fix this i need to go to work in 10 hours....
my terminals on my bat is pretty bad i bought new connecters there going on next maybe a bad connection.. well off with my multimeter to check my inverter wires and try again.
