Shortys vs longtubes
  • Thread starter Thread starter Cobain03
  • Start date Start date Sep 25, 2006
Cobain03
996
Lexington, Ky
Sep 25, 2006
  • Sep 25, 2006
here my delimma. i currently have patriot tri y headers. because of the poor quality, i had to take a hammer and torch and bend one of the tubes cause the pitman was hitting it. that area is about half dented in. also cause of the headers, i had to jack my engine up about an inch to get the headers to clear the fenderwell.
so, would shorties be any better?
Stanger007
2,015
Baton Rouge, LA
Sep 25, 2006
  • Sep 25, 2006
The shorties won't hang nearly as low and you'll avoid the interference w/ the steering but you will lose some lowend torque in the swap.
You'll also have to have your midpipe lengthened to make up the difference between the longtubes and the shorties.
Surely there are some headers that are a better fit?
Wes
Spoofty
61
  • Sep 25, 2006
I have posibly the cheapest header around and they are a perfect fit. Full length Flowtech for $89.
The only issuse was two of the bolts were alittle tight against the primary tubes. A small dimple in the tube fixed it.
I'm running a 302 C4 with power steering and have no issuse with the steering.
bnickel
5,640
lubbock, texas
Sep 25, 2006
  • Sep 25, 2006
i've got hedman shorties, actually more of a mid-length but they call them shorties, and they fit well and there is no interference with anything at all. they were pretty cheap too, i paid 99 bucks for them. i think the price has gone up since i got mine but not much.
Max Power
1,774
St Paul
Sep 25, 2006
  • Sep 25, 2006
I have the Hedman shorties as well but I got ceramic coated, and even then, they were only a bit over $200.
DukeGnarley
597
Auburn/Ellensburg, Wa
Sep 25, 2006
  • Sep 25, 2006
I had the hooker comps in my coupe. they fit just fine, only needed to trim one of the UCA bolts because witht he shelby drop it stuck in a little too far in just the wrong spot.
iskwezm
4,159
20
79
Rowland Heights,California
Sep 25, 2006
  • Sep 25, 2006
Cobain03 said:
here my delimma. i currently have patriot tri y headers. because of the poor quality........
thats not poor quality, most of the try-y's fit like that. You just put them on and deal with it. I doubt your losing any performance from "clearancing" a primary tube, unless its really smashed. Mine is beat in a little, but nothing i worry about.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 25, 2006
  • Sep 25, 2006
Yeah, Hookers. I had Comps in my old '65 Notch with a 289 and Toploader with zero clearancing needed. I now have Comps in my '68, but I had to dent them slightly to clear the frame rail and the scattershield.
Less expensive longtubes may fit well also, but I don't have experience with them.
EDIT: The losses between shorties and longtubes will be negligible with a mild engine. It won't sound quite as good if the exhaust is loud, but you gain lots of clearance.
D
D.Hearne
11,730
south louisiana
Sep 26, 2006
  • Sep 26, 2006
Well said. Even with a hotter motor, the difference can sometimes be only measured on a dyno or at a track. Last long tubes I had were on a big block Stang and they were an absolute pain in the ass to deal with, in every regard. To me they just ain't worth the hassles.
bnickel
5,640
lubbock, texas
Sep 26, 2006
#10
  • Sep 26, 2006
  • #10
yeah i really like my shorties a lot. when i sell the stang i'm going to buy a 69 cougar that a buddy has and i'll probably run another set of the hedman shorties, though this time i'll probably get the elites since they have a thicker flange. i haven't had any problem with mine so far but the thicker flanges would sure be nice insurance.
M
mikehuyck
9
Nebraska
Sep 27, 2006
#11
  • Sep 27, 2006
  • #11
Not to get off the subject, but for you guys that have the Hedamn headers:
Is the thermal coating the same or similar to ceramic coating? Not really seeing these details on Headman's site, but the elites come "thermal coated" standard and the pics look just like ceramic... Engine compartment looks are almost as important to me as functionality, and nothing looks worse than rusty headers.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
