Should I?
  • Thread starter Thread starter tjmaxx
  • Start date Start date Feb 7, 2006
tjmaxx
157
  • Feb 7, 2006
I know I dont have to but if I am changing my spark plugs should I change the spark plug wires as well? I bought the plugs but forgot all about the wires Will it make much of a difference? I am thinking of gas mileage not performance since it is a Nissan not a stang.
legalize420
1,541
South Florida
Feb 7, 2006
  • Feb 7, 2006
unless the wires are dammaged, you will be fine.
tjmaxx
157
  • Feb 7, 2006
They looked pretty good to me, thanks for the reply.
HISSIN50
34
129
Feb 7, 2006
  • Feb 7, 2006
With that little info, who can say.
Does it use a dizzy or is it direct ignition (coil packs)? Any aftermarket ignition components?
How many miles on the wires? Any spark leakage?
Your guess will be better than most of ours. Sounds like the wires are alright though (not like you cant swap them later).
Good luck.
JBeezy53
559
Sacramento, Ca
Feb 7, 2006
  • Feb 7, 2006
If they are working good and not damaged there's no need to change them.
tjmaxx
157
  • Feb 7, 2006
I do not know the exact mileage that are on the plugs and wires, but I do know my gas mileage has gone down some and figured it might have something to do with me needing new plugs. I have only put 15k on the car but it has 139k and I do not know the last time the last owner replaced the plugs, but I figured I could do the wires later if needed.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
