  • 2005 - 2009 Specific Tech
Sirius post
  • Thread starter Thread starter Humboldt Stang
  • Start date Start date Sep 6, 2007
Humboldt Stang
64
  • Sep 6, 2007
I installed the Sirius plug and play, the Stratus.
Easier than I thought.
I think I did a good job routing the wires.
I didn't want the antenna on the exterior of the car, so I put the antenna into the well for the carseat hook, removing the hook cover completely.
No wire on the rear deck, and the antenna fits nice and snug for a clean look.
Reception is great.
Also took shot from the other side so you can see where I routed the wires.
The wires from the unit into the crease by the glovebox are all you see.
I'm pretty happy.
P
plnfixr320
55
High Desert CA
Sep 6, 2007
  • Sep 6, 2007
I like the clean antenna install. Great job!
speed1972
891
Denver, CO - Buckley AFB
Sep 6, 2007
  • Sep 6, 2007
Love the antenna install..... Might go that way when I do mine. I need to figure out a way to mount that and my Ipod so I don't put any holes in the dash tho..... Need a clean look myself. Looks good overall though!!
LB
Humboldt Stang
64
  • Sep 7, 2007
I hear you about the holes.
Mine is held on with tape.
After taking the pics I cut the heads off of a couple of black screws and taped them over the holes, looks like it is screwed in.
speed1972
891
Sep 7, 2007
  • Sep 7, 2007
Nice!!!
stanmckinney
1,188
Sep 8, 2007
  • Sep 8, 2007
You can actually install a Sirius antenna under the rear deck, completely hidden, and still get great reception.
I replaced my factory radio with an Alpine that controls my Sirius and ipod.
I had factory Sirius but the factory antenna won't work with any other radio. And the factory drills a hole in the trunk to mount the antenna. So I mounted the new antenna under the rear deck where it is completely hidden. People see the factory antenna but it is not the one that delivers my signal.
I wish Ford would use antennas that will work with aftermarket systems or at least not drill a hole in the trunk.
My main point is that you can hide the antenna under the rear deck and get good reception.
  • dan50
  • Jul 18, 2026
dan50
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
1976 Cobra II fuse problem - Solved (I hope)
  • Rick Tanner
  • Jan 8, 2025
1974 - 1978 Mustang II Talk & Tech Jan 8, 2025
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
