sitting high??
  • Thread starter Thread starter jimc347
  • Start date Start date Nov 30, 2005
J
jimc347
77
  • Nov 30, 2005
i have the koni front struts in my car with the hotkis camber adjustment and the front of the car sits high up. how can i lower this??????
J
jimc347
77
  • Nov 30, 2005
anyone?
88gt
794
Drillers cabin
Nov 30, 2005
  • Nov 30, 2005
How new are they? It's possible (unlikely, but possible) they need to settle.
What about your control arm bushings...how old are they? If new, did you tighten them before the car loaded the suspension? Are they for a 94 & up, not the 87-93?
If all is correct, settled in place, may be time for lowering springs. I personally have Bullitt springs on my 88, I really like the ride height and quality...
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 30, 2005
  • Nov 30, 2005
Maybe your front does'nt sit high, it could be your back sitting low, which is common problem.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 30, 2005
  • Nov 30, 2005
lowering springs
J
jimc347
77
  • Dec 1, 2005
well i bought the car with them on there. from the top of the tire to the bottom of the fender is about 7 0r 8 inchs.????? is it the struts??
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 1, 2005
  • Dec 1, 2005
What size tire is on the car?
88GT17MA
289
  • Dec 1, 2005
Springs are what effects ride hide, not shocks/struts.
You already have lowering springs on there?
The end of the springs are suppose to sit in the perch a certain way, which could also be your problem.
J
jimc347
77
  • Dec 1, 2005
i have no lowering springs and they are 16' wheels. it's diffenitly not normal.
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Dec 1, 2005
#10
  • Dec 1, 2005
  • #10
-Drag setup?
-Compressed heigth of the strut is incorrect?
-Control arm to k-member bolts tightened when suspension was hanging?
-Factory type springs and the car has been lightened drastically up front?
-Spring not properly in it's nesting area on the control arm?
-Body in the trunk?
-Someone put truck springs in it?
-The spring isolators are too thick?
-You measured it with the cm side of the ruler?
-Blocks in the springs?
-Blocks not in the springs?
-WTF?
Flavadave4
1,044
21
49
Utica, NY
Dec 1, 2005
#11
  • Dec 1, 2005
  • #11
your springs are what controls the height.
buy some lowering springs, get it alligned and you'll be all set
93Stang5oh
266
Manchester, Iowa
Dec 1, 2005
#12
  • Dec 1, 2005
  • #12
Get some UPR Adjustable Coil Over springs and set the ride height the way you want it.
MrKwik
1,008
Kansas City, Kansas
Dec 1, 2005
#13
  • Dec 1, 2005
  • #13
Ive never even had one set THAT high without a motor. Sounds like someone wanted to go offroad. Go spring shopping.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 1, 2005
#14
  • Dec 1, 2005
  • #14
Actually, gas pressurized struts/shocks do have some ability to affect ride height as they contribute a bit to the spring rate. But it sounds like this is more drastic than that.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
