sloppy steering
  • Thread starter Thread starter davestang67
  • Start date Start date Mar 8, 2009
D
davestang67
11
Marana, AZ
Mar 8, 2009
  • Mar 8, 2009
could a worn steering column shaft cause slop in the steering wheel? there is about 2 inches of slop. the steering box has already been replaced.
P
phutch11
328
Mar 8, 2009
  • Mar 8, 2009
Subscribing - I have the exact same issue. Was tight, now sloppy - maybe 1000 miles on the rebuild. Is there a way to adjust them?
Posted via Mobile Device
wicked93gs
1,198
229
93
Nashville TN
Mar 8, 2009
  • Mar 8, 2009
some slop is just how they seem to be, its the main reason people upgrade to rack and pinion systems, if i remember correctly though there is an adjustment on the stock box....but even all the way in it doesnt help much
2nd Mustang
2,488
Southern California
Mar 9, 2009
  • Mar 9, 2009
After reading this thread, I went out to look at my 67 coupe with manual steering as I just happen to have it today. My steering wheel looks like it has a little more than two inches of travel by the naked eye. The car does drive straight though with no wandering on the road. I think it's just old type engineering as stated before by wicked.
P
phutch11
328
Mar 9, 2009
  • Mar 9, 2009
There's actually an excellent write up on adjusting the steering box at the following link.
http://www.stangerssite.com/adjustment_nn4.html
I'm gonna give it a try.
Good luck....
D
davestang67
11
Marana, AZ
Mar 10, 2009
  • Mar 10, 2009
my steering box is a newer flaming river box. I believe the internal components are different and it does not have a worm gear set up. do you know the procedures to adjust these type of boxes?
P
phutch11
328
Mar 10, 2009
  • Mar 10, 2009
Nope - tried calling Flaming River?
G
gjz30075
250
Roswell, Ga
Mar 10, 2009
  • Mar 10, 2009
There's probably nothing wrong with the box. You didn't say what year car but your name implies a '67. If so, you probably have a rag joint in the system. It connects the shaft to the box. It's a disc shaped piece of rubber that's prone to wear and gives lots of slop to the steering feel. Check that first before diving into the box.
D
davestang67
11
Marana, AZ
Mar 14, 2009
  • Mar 14, 2009
it is a 67. the rag joint looks good and all the other components (ps control valve, tie rods etc. feel solid. i will call techs at flaming river for more info.
G
gjz30075
250
Roswell, Ga
Mar 14, 2009
#10
  • Mar 14, 2009
  • #10
Should be easy enough to check. Will take a second person. Have one person turn the wheel, within the slop, and the other take a look at the pitman arm. Assuming you can see the column all the way into the box (on a '66, you can't, it's covered by an outer column), you should be able to see the pitman arm move. If not, then the slop is in the box and it'll require adjustment or Flaming River to do something about it. I've heard of very sloppy new boxes from Flaming River but they've always been able to correct the situation.
L
69 tilt steering column endplay
  • loubischoff
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 10, 2026
loubischoff
L
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
