Slow cranking/no start when hot
  • Thread starter Thread starter millhouse
  • Start date Start date Jun 14, 2006
millhouse
1,985
Simpsonville, SC
Jun 14, 2006
  • Jun 14, 2006
Alright…it all started after I installed my turbo kit and relocated the battery to the trunk.
The symptom…after the car warms up for 10 minutes or more the starter turns over slooooowly.
Now, the alternator is in close proximity to my passenger side turbo exhaust housing….however the amps down ever seem to get low, so I wouldn’t think charging would be the issue.
I have 1/0 gauge + going up to the solenoid and 4 gauge from the solenoid to the starter. For the - I have 4 gauge going from the - to a bolt in the rear subframe (quadshock area) and another running from there up to the firewall. I then have another 4 gauge running from the firewall to the head as well as the stock strap.
I currently run a megasquirt to control everything and still have the start issues…however I had the same issue when running the stock computer.
Also…I have my turbo downpipes wrapped with two layers of header wrap which includes the area which the pipe passes the starter.
I replaced the starter to ensure that it was not the problem.
The battery does not seem to be the culprit as I have used three different once…including a red top ultima.
I am able to restart the car while hot by either jump starting or push starting.
It's my understanding that a faulty TFI module and/or PIP sensor will not cause a slow start as described above. Is that a correct assumption?
It also seem as if my wiring should be plenty sufficient as far as my ground is concerned. I may end up swapping my battery to chassis ground for a larger gauge wire just for ****'s and giggles. I also have a couple of turbo blankets on the way to limit the heat the alternator sees.
I am slowly approaching my wits end here as nothing I do seems to help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 14, 2006
  • Jun 14, 2006
Rear mounted battery ground wiring. Follow this plan and
you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post
to a clean shiny spot on the chassis near the battery. Use
a 5/16” bolt and bolt it down to make the rear ground.
Use a 1 gauge or 1/0 gauge wire from the rear ground
bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected
the battery ground wire to the chassis ground where the
battery was mounted up front. Use a 5/16” bolt and bolt
down the 4 gauge engine to chassis ground, make sure
that it the metal around the bolt is clean & shiny. This
is the alternator power ground.
The computer has a dedicated power ground wire with
a cylindrical quick connect (about 2 ½”long by 1” diameter.
It comes out of the wiring harness near the ignition coil &
starter solenoid (or relay). Be sure to bolt it to the chassis
ground in the same place as you bolted the alternator power
ground. This is an absolute don’t overlook it item for EFI cars
Picture courtesy of timewarped1972
Crimp or even better, solder the lugs on the all the wire.
The local auto stereo shop will have them if the auto parts
store doesn't. Use some heat shrink tubing to cover the lugs
and make things look nice.
millhouse
1,985
Simpsonville, SC
Jun 14, 2006
  • Jun 14, 2006
Yep...with the exception of my negative cable being a bit to small I've done all of that. I'm going down now to replace the negative to chassis with a larger gauge wire and I'll be throwing a new TFI module on there just to be safe.
HISSIN50
34
129
Jun 14, 2006
  • Jun 14, 2006
You were correct - the TFI and PIP have nothing to do with cranking.
Jumper cables can be used in parallel with existing cables to find a deficient permanent cable.
Good luck.
millhouse
1,985
Simpsonville, SC
Jun 14, 2006
  • Jun 14, 2006
Good luck.
Yep...just got done trying that...and nope...it did not seem to work.
I ran both + and - cables from the battery up front to the starter solenoid and firewall respectively....and nada.
I felt the wire that ran from the solenoid to starter and it felt hot, so I ran a cable from the + on the solenoid to the + on the starter....and again, nada.
I felt the starter itself and holy hell was it hot. My downpipes in that area felt cooler than the damn starter did!
As far as the alternator being to close to the turbine housing...I dont think so. I can monitor my voltage reading in megasquirt, and although it drops a bit when the engine bay starts to get heatsoaked, it really doesn't drop below ~ 13-13.2 volts.
Soooo...I have narrowed my search down to a few more things.
One: The turbo blankets should be on their way shortly and should help reduce heatsoaking any wires in the engine compartment. I do not think this is a fix, however it certainly should help.
Two: I'm going to have to buy some thermotec starter wrap to help shield some of that heat away.
Three: Buy the highest CCA battery I can find and throw it in there. This however seems more of a band-aid and I would like to solve the problem.
Any other Ideas would be appreciated.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 14, 2006
  • Jun 14, 2006
Heatsoak sounds like the problem. If the starter is hot, the resistance in the wiring (inside the starter) increases dramatically. This usually leads to your slow cranking issues because the wiring inside will not pass enough voltage to the starter.
You said you replaced the starter, was it the smaller style from the later model year fox cars?
millhouse
1,985
Simpsonville, SC
Jun 14, 2006
  • Jun 14, 2006
Nope...I didnt find that out until after I installed the replacement. It has a lifetime warranty....but I wonder if they will allow me to exhange it for a newer style one. Hmmm...perhaps a trip to a different autzone is in order.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jun 14, 2006
  • Jun 14, 2006
My thoughts: with the larger diameter case and such close proximity to your turbo setup there is a reduced amount of air gap between the two. In a stock setup the air would act as insulation between the heat source so the starter isn't "over cooked."
However, simply installing the smaller case starter might not restore enough gap between the two so a starter blanket might still be required.
millhouse
1,985
Simpsonville, SC
Jun 14, 2006
  • Jun 14, 2006
I do agree and will likely purchase one tonight. It appears the 93 style starter is a bit more money than the 89, so it's likely that they will atleast require me to pay the difference for the newer style.
If and when I figure this damn thing out I'll be sure update.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jun 14, 2006
#10
  • Jun 14, 2006
  • #10
Good luck man!
millhouse
1,985
Simpsonville, SC
Jul 2, 2006
#11
  • Jul 2, 2006
  • #11
Update....
I wrapped the starter with some thermotec starter wrap and....voila, problem solved. After replacing every logical item including two layers of header wrap on the downpipe, a simple $20 item solved the problem.
Live and learn.
I can finally take her up to the store and even drive her to work without fear of the dreaded hot start problem.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jul 2, 2006
#12
  • Jul 2, 2006
  • #12
Glad to hear!
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
