i may have a problem here. i got smoke coming from the dipstick tube when i floor the car hard. i can see smoke coming from the cowl hood and in the mirror i see smoke behind me but it is NOT coming from the tailpipes. i have a working pcv valve. when i take off the oil fill cap there is no smoke but when i disconnect the pcv valve, there is smoke at idle. the cylinders were very clean and had no ridges in them when i put the new heads on. i have not checked the compression yet but i am assuming the rings are good since the cylinders are. also i noticed that i am blowing oil out from the rear of the intake and i did not use the cork end gaskets. what do you think is going on.
