smoke?
  • Thread starter Thread starter flashback87
  • Start date Start date Jul 9, 2011
flashback87
345
Cleveland, OH
Jul 9, 2011
  • Jul 9, 2011
i have been doing some research and got some good info but i wanted to ask this question anyways hoping for some help.
i bought 87 gt in 2009 and it has been smoking a little ever since i had it. it does not smoke at idle, start up or if i am driving it easy. it smokes when i start to get on it. i have followed behind the car with some one driving it and others have followed behind me, the smoke is a greyish white with just a little of a blue tint. when it does smoke it usually comes out in quick plume/cloud and then stops. i put an oil catch can in to see if that would help and i have changed the pcv valve and screen. the pcv helped just a little.
the car has an o/r h pipe with no tail pipe, just stops at the mufflers. i think the owner before me was in the engine as well because they installed roller rockers and when my mechanic did my timing chain there was a double chain and he said they came stock with just one. also, there is a lot of black soot in the muffler opening.
one last thing. i changed the plugs when i first got the car and one of the plugs had a cap on it. the car drives good and only loses a little oil and that might be because i drip some off the oil pan bolt.
sorry for such the lengthy post but i was hoping you guys could narrow down what is causing this smoke and how sserious it is. i am basically trying to decide if i should get some body work down or focus on the engine.
thanks for all the help!!!!!!
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 9, 2011
  • Jul 9, 2011
I would do a compression test to see if you have a weak cylinder, good way to check if the rings are the culprit
J
jeffwilson0
20
NB, Canada
Jul 9, 2011
  • Jul 9, 2011
Sounds exactly like mine. It's enough smoke I can see it behind me when I'm on it WOT. I assume it's rings with mine as it's had lots of nitrous through it. I'm driving it till it blows, cause it still works awesome. Sometimes I have a hard time telling it's blue through the tire smoke....
J
jeffwilson0
20
NB, Canada
Jul 9, 2011
  • Jul 9, 2011
flashback87
345
Cleveland, OH
Jul 9, 2011
  • Jul 9, 2011
i figured compression test would be the answer. i guess i better research how to do one anything else i should do or check for?
also, like i said it drive really good. can i still continue to drive it?
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 10, 2011
  • Jul 10, 2011
Compression tests are easy, just buy or rent a kit. The hoses thread into the spark plug hole, disconnect the coil plug then crank it over a few times
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
