Smokin'
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Sep 2, 2009
Black Sun 5.0
1,337
L.I., N.Y.
Sep 2, 2009
  • Sep 2, 2009
So I've noticed some smoke coming out of my tails, seems to be worse after the car is warmed up. I noticed that it is at its worst when the car is warm, I shut it down for a few, then restart. Does this sound like rings or valves to anyone? I forgot to mention: I've been using oil, that's why I suspect rings or valves.
T
time only
461
Miami,FL
Sep 2, 2009
  • Sep 2, 2009
If your 5.0 are like most of the other one out there,you will be pushing hundred thousand miles on the engine easy. They are build strong and tough,but sooner or later it will reach its limit.
I have hundred thirty thousand miles on my engine and it is still running strong,and so far it is not smoking or burning oil. Keeping my finger cross.
Get a compression/leak down test done and you should get a fair idea what shape your engine is in.
Good Luck.
Black Sun 5.0
1,337
L.I., N.Y.
Sep 2, 2009
  • Sep 2, 2009
Yeah, this engine only has about 13k on it, but it sat around for a while as the car was being rebuilt.
Chrome_Rust
530
Findlay, Ohio
Sep 2, 2009
  • Sep 2, 2009
the possibility exists that your valve seals are bad. Depending on how long the engine sat could be the factor in that. Also, even though the engine has 13k, you may have a ring issue. what kind of rings did you use during your build?
Black Sun 5.0
1,337
L.I., N.Y.
Sep 2, 2009
  • Sep 2, 2009
I'm not sure what rings were used, probably something equivilent to standard stock rings since the motor was ordered by the shop from Ford.
9
90StangLX
419
Illinois
Sep 4, 2009
  • Sep 4, 2009
Could be valve stem seals, those are (relatively) easy to replace. Just need compressed air to hold the valves up.
Black Sun 5.0
1,337
L.I., N.Y.
Sep 4, 2009
  • Sep 4, 2009
Thanks for the reply. Yeah, it doesn't seem to smoke while driving, or at least not that i can see. I had another car years back with blow by issues that would put out a puff every few minutes, this car is not doing that. I'm also going to change the PCV valve in case that's the culprit.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
