  • SN95 4.6L Mustang Tech
smoking egr? help..
  • Thread starter Thread starter stangfl
  • Start date Start date Apr 1, 2005
stangfl
20
FL
Apr 1, 2005
  • Apr 1, 2005
Recently replaced my engine after I blew it up from a kenne bell trip. When I fire the car up it idles alright, but after a couple of mins smoke starts to come out of the egr and after I shut the car off and feel where it meets the plenum its hot as hell, I know some heat should be felt but whoa... Any ideas on why this could be happening....
Also after the engine install the clutch pedal is way weird, guessing its the cable... how hard is that adjust, I will probably get the steeda one but for now I need a stock fix.
THANKS
vristang
4,933
101
124
Seattle
Apr 2, 2005
  • Apr 2, 2005
When I replaced the exhaust on one of my cars I damaged the pipe that runs from the exhaust to the EGR. Basically I had broken the pipe weld on the EGR. This would explain the smoke. I could barelly see the crack in the weld so look carefully.
white99gt
4,649
stockbridge,Ga(near atlanta)
Apr 2, 2005
  • Apr 2, 2005
the egr is probally smoking becuase you have gotten some oil or grease on it.As far as getting hot.Its suppose to .It does have exhaust gas running to it..
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
