Aright well heres my problem. Ive had my engine finished for a while now and its in the car. But i really havnt been driving the II alot because im also in the process of getting a new hood made (cowl). And around here its illegal to drive with out a hood. So the farthest Ive drivin it is just around my subdivision. I have around 50 miles on the new build so its definitly not broken in yet. So heres the problem it will drive fine and run real good when im just cruising but when i gun it a bit and let off the gas a big puff of smoke billows out from each side of the engine. Remember no hood so i can see where it comes from. Now it wont do it if im just give it gas slowly. I can be going 60mph and as long as i dont give it alot of throttle at once it wont smoke. What can this be. I cant get it to do this while im in the garage. Even if i rev it real high. So it only does it under load. Ive replaced the header gaskets and i even took off the valve cover breather on the driver side and put a pcv valve on there cause i thought there might be to much crankcase pressure building up. But that didnt fix it. If anything that caused me more of a headache cause i had to retune the carb and change the timing because the pcv valve messed up my engine vacuum and caused the motor to run like crap. So right now im stumped. The smoke isnt blue so i dont think its oil but if i had to give it a color id say brown. Oh yeah I also resealed my valve covers just to make sure they wernt leaking. And when i was doing that i made sure the heads where torgue correctly and they were. Does any one have any suggestions as to what this might be. Any help would be great.
Pat
Btw....What is a good oil pressure for a 302 with the stock oil pump say at 900 rpms
Pat
That's a good one.... Could it be paint burning? (headers?) How do you have your PCV system hooked up? You should have one, and there's really no reason not to. Doesn't really hamper performance.
