Still fighting the same smoking problem. For those of you just joining, I have a '96 GT. It has this problem of belching blue smoke when you let it sit and idle for a little bit. Only happens when it idles for a while then you rev it softly or all the way down and let up. Doesn't smoke while driving or accelerating.
So, i've tried replaceing the PCV valve, and was going to replace the valve stem seals the other day but noticed something interesting.......
When i got the intake manifold off I found that it had a decent amount of oil laying in the bottom of it. Also, the #8 and #4 ports on the head were covered in oil all the way down to the valve. the rest of the cylinder ports had a light coat of oil on the head walls. But, 8 and 4 were by far the worst, i could take my finger and wipe the oil from the head and the intake manifold gasket centering hole in the head was full of oil.
So, it's pretty much got to be the PCV system, there is no other way to get oil into the intake.
So i made a makeshift oil seperator out of a mightyvac resivoir and some hose. Check out the pics, is this an excessive amound of oil? the car had been running about 5 mins to collect that much oil. Why is it doing this and how the hell to I make it stop?
