  • 1994 - 1995 Specific Tech
Snap... Goes the water pump bolt...
  • Thread starter Thread starter fyassine
  • Start date Start date Aug 6, 2008
fyassine
331
Austin, TX , US
Aug 6, 2008
  • Aug 6, 2008
I was in the process of trying to change my water pump and snapped one of the bolts off on the left hand side.
So now I have two show stoppers that I have to take care of before I can put this sucker back on.
I have two questions:
1. It is possible to get a set of high quality water pump bolts to replace the ones I have in now?
2. Anyone know the size/dimensions/thread type of these bolts so that I know what to ask for?
2. Since the thread of the hole is pretty far in, what could I use to get the rest of the broken bolt out and would I need to fix the thread as well when I do this?
I really am hoping to avoid having to remove the timing cover.
Thanks
str8stang036
1,382
Miami
Aug 6, 2008
  • Aug 6, 2008
I went to Lowes or Home Depot when I was missing bolts for my water pump. Arp is another good brand if you want high quality. I believe they have a water pump bolt kit for our year.
Y
YELLOW 94
428
Rio Rancho NM
Aug 6, 2008
  • Aug 6, 2008
You can call arp and tell them the length, and size of the bolts you have. They will match what you have with arp bolts. There is no specific kit for our cars. Found this out after ordering 2 differnt sets.
later
Orlie
Redsnk95
2,243
Houston, TX
Aug 6, 2008
  • Aug 6, 2008
Welcome to the club I am still running without one water pump bolt. I don't think ARP makes a kit for our year cars. Just have to go to the hardware store and get the sizes you need.
fyassine
331
Austin, TX , US
Aug 6, 2008
  • Aug 6, 2008
Are you getting any types of leaks or did you some how double up on RTV or gaskets?
str8stang036
1,382
Miami
Aug 6, 2008
  • Aug 6, 2008
ARP 454-1504 - ARP Timing Cover Bolt Kits - summitracing.com
bayellowstang
462
Carlisle, PA
Aug 6, 2008
  • Aug 6, 2008
Depending on how far in the block it is, there is a tool called and easy-out. It is basically a reverse drill bit. You use a small drill bit to get a hole for the easy-out then use a ratchet and lots of luck and elbow grease to unscrew it.
Zero_chance
1,244
Maricopa, AZ
Aug 7, 2008
  • Aug 7, 2008
Like was said, an extractor kit would be your best bet but youd probably be better off taking the timing cover off to make sure youre actually drilling in the center of the broken bolt. Then an extractor gets put in with a ratchet counter clockwise. Easier to do it right the first time. Plus youll probably want to chase the threads of the hole after the old bolt is out because theres likely something causing it to hang up if you broke it. You might want to clean the threads of the other bolts on a wire wheel too, they look a little rough.
95cobraguy
637
11
Concord, NC by way of LI, NY
Aug 7, 2008
  • Aug 7, 2008
they are 5/16 bolts. i ordered all stainless bolts from Bolt Depot - Nuts and Bolts, Screws and Fasteners online to replace the factory bolts. its probably necessary to remove the timing cover, once u have it off soak the broken bolt with penetrating oil and before u start monkeying around with ez outs try using a vice grip on the broken part and see if u can break it loose that way.
donkey_punch
565
northern****ingjersey
Aug 7, 2008
#10
  • Aug 7, 2008
  • #10
thats a great link, and will come in hand. thanks 95cobraguy
and as i wait for my water pump to get here, i can see this happening to me. keeping fingers crossed
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 8, 2008
#11
  • Aug 8, 2008
  • #11
Yes ... That sucks when that happens
Get GOOD bolts ... not ... CHEAP replacement bolts :Word:
and
Be sure to use anti-seize on the threads of the new bolt
Grady
Methodical
1,192
11
59
Clinton, MD
Aug 8, 2008
#12
  • Aug 8, 2008
  • #12
final5-0 said:
... Be sure to use anti-seize on the threads of the new bolt
Grady
Yeah. I put anti-seize on every nut or bolt I take off and put back on - car, home everywhere.
Also, as far as size of the bolts, you can take the bolts to HD or Lowes and in the bolt section they have sample nuts where you can screw them into and get the size that way. Put some heat on the broken bolt that should help.
Str8stang, have you used that kit. I know when I was building my engine I purchase an ARP engine bolt kit and it was basically worthless for our cars so I sent it back to Summit and just reused the old bolts.
Redsnk95
2,243
Houston, TX
Aug 8, 2008
#13
  • Aug 8, 2008
  • #13
No, no leaks just left it as is.
Redsnk95
2,243
Houston, TX
Aug 8, 2008
#14
  • Aug 8, 2008
  • #14
I am sure that fits 93-down setups not ours.
Venom351R
4,548
41
98
MAINE
Aug 9, 2008
#15
  • Aug 9, 2008
  • #15
Order Here!
fyassine
331
Austin, TX , US
Aug 12, 2008
#16
  • Aug 12, 2008
  • #16
I ended up pulling the front cover off to get to this sucker.
I was a bit pissed when I could unscrew it using the tips of my finger. I guess I can look upon this as a opportunity to change the timing chain/sprockets (312,000 miles on it).
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
