I've been looking around the forums and found issues similar, but mine has a twist. Basically, my oil pressure since I got the car not too long ago has always sat right at the bottom normal line, and I've always figured it was fine because it ran fine and I know the stock gauges are janky. However, for a bit now after I've been driving for a while and my car is warmed up(temperature never really goes over the second or middle line unless I'm sitting in traffic) when I go to stop at a light, and the RPMs go under 1000,the oil pressure completely drops. It still runs fine, but drops completely off, and will somewhat kick back up real quick but fall, until I give it gas and get the rpms above 1k again and then it's right where it usually is. Still running normal the whole time. The weird thing is though, if my car is doing this, and I shut it off, and then come back within 30 minutes of parking it and try to start it it'll crank, Rev up, and then rpms fall and die. It'll do this usually twice and then on the 3rd try will idle, but insanely rough, and I pretty much have to Rev it up to about 2k to get it to fall down and idle on its own. After that, when I get it going down the road it runs fine again.... Any ideas??? Any other symptoms that could go along with this?? Let me know if I can explain anything clearer.. Any help is appreciated!! I know the gauges are crap, but the barely idling part is what concerns me.
sorry for the wait
I WILL respond d if I figure it out though!
