Soaked Spark plugs??
  • Thread starter Thread starter asecretfile
  • Start date Start date Jul 25, 2008
asecretfile
228
  • Jul 25, 2008
87 GT MAF converted
misfiring....
pulled the plugs and have a little gas on all the spark plugs some more than others. This is while the car is cold (Car actually somehow idled like this long as I feathered the gas)
havent replaced the wires and plugs yet, but have new ones on hand...just trying to make sense out of this first
Im at 10* timing with GT40P heads, maybe bump it up a little to 11 or 12?
thanks
2BADSTANGS
385
Colorado
Jul 26, 2008
  • Jul 26, 2008
Wich mass air conversion did you use and what lb. injectors are you running?
asecretfile
228
  • Jul 26, 2008
this one
MAF - Mustang Mass Air Conversion - StangNet - The Mustang Network
its been maf converted for a while now...just had this prob since the head swap
19lb injectors
by the way got it idling fine last night with new plugs and wires...but when I let off the gas after a small rev of maybe 3000 rpms it wants to stall out unless with the gas pedal I ease it back to idle (900 rpms)
its also slow to return to idle from a rev...does not surge, just returns slow
2BADSTANGS
385
Colorado
Jul 27, 2008
  • Jul 27, 2008
Well for the idling issues, check this thread, http://forums.stangnet.com/698148-help-me-create-surging-idle-checklist.html If you fix whats causing the idle problem, it might cure or at least help your other issue. As it sounds like air fuel delivery/ monitoring/ processing issues.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 27, 2008
  • Jul 27, 2008
did you check for any vac leaks?
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
