  • SN95 4.6L Mustang Tech
SOHC and DOHC blocks the same??
  • Thread starter Thread starter Eric1
  • Start date Start date May 17, 2004
E
Eric1
Kingsland, GA
May 17, 2004
  • May 17, 2004
Other than being iron and aluminum, are these blocks the same?? Can I use an iron sohc block for a buildup on my 96 cobra? thanks, eric
R
Roger_4.6_96
1,209
Reno,NV
May 17, 2004
  • May 17, 2004
Yes you can heads bolt right up
Aaron 4.6
2,695
Georgia
May 17, 2004
  • May 17, 2004
Agreed. Certainly an affordable option.
neoclasiccl
3,043
Help I can't see !!!!!!
May 17, 2004
  • May 17, 2004
same stuff. If you want the best block available it would have to be the new aluminum mach1 block.
Hissmann
243
West Virginia
May 17, 2004
  • May 17, 2004
The best block is the Aluminum Teksid block for the 96-98 and maybe some 99 cobras. The strongest aluminum block for a 4.6.
neoclasiccl
3,043
May 17, 2004
  • May 17, 2004
I stand corrected I haven't heard of that setup before.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 17, 2004
  • May 17, 2004
ya, in sean hylands book he makes a really big deal about how great the teksid's are. if i remember correctly they were also used in the mrk 8's
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
Fox Block Decode
  • PonyGTrider
  • Jun 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
PonyGTrider
