  • 1994 - 1995 Specific Tech
solid motor mounts
  • Thread starter Thread starter 94opalgt
  • Start date Start date Mar 19, 2009
94opalgt
358
AKRON,OHIO
Mar 19, 2009
  • Mar 19, 2009
all i can find are ones for the fox car's, do they work on our's? i would assume they do, but i want to make sure. i just did a fox TB swap and installed energy suspension motor mounts and now my hood won't close. it hits the air tube on top of the TB, so i got to drop the motor a bit and i don't want to put stock mount's back in it.
THANK'S FOR THE HELP GUY'S.
95Vert383AOD
1,133
34
69
New Bedford, MA
Mar 19, 2009
  • Mar 19, 2009
Yep they work. 351/302 use the same motor mounts all years i believe.
94gsl5.0
223
seatown
Mar 20, 2009
  • Mar 20, 2009
I am running some HPM solid drop mounts. Fit ok with a stock oil pan. If your running an aftermarket pan, you will have to space the mounts to stock height.
95Vert383AOD
1,133
34
69
New Bedford, MA
Mar 20, 2009
  • Mar 20, 2009
I use solid steel lowering mounts from ebay. and a 7qt Canton pan. It just barely clears. Beauty of the solid mount is that you can run very close to the steering rack because the motor wont rock in the k member like with rubber mounts.
94gsl5.0
223
seatown
Mar 20, 2009
  • Mar 20, 2009
How much of a drop did you get with the Ebay mounts? Are you running a stock K-frame?
95cbr331
79
Port Orchard, WA
Mar 20, 2009
  • Mar 20, 2009
I used maximum motorsports solid motor mounts. Good product and they've held up well to the 525ft/lbs of torque as well helped with many many clearance issues.
ProKiller
3,064
15
78
PA
Mar 20, 2009
  • Mar 20, 2009
how much vibration do you get with the solid mounts? i've thought about doing this numerous times but am always afraid to pull the trigger cause of the vibrations.
94gsl5.0
223
seatown
Mar 20, 2009
  • Mar 20, 2009
I actually did not really notice a difference in vibrations between the two mounts. But then again my new motor is balanced alot better than my old 5.0 and i never had the solid mounts on my 5.0 so the comparison between the two is kinda apples to oranges.
94opalgt
358
AKRON,OHIO
Mar 21, 2009
  • Mar 21, 2009
thanks guys
95Vert383AOD
1,133
34
69
New Bedford, MA
Mar 22, 2009
#10
  • Mar 22, 2009
  • #10
Personally vibration with solids aren't that bad. I have a stock K member with a wider 351 pan. Pan almost hits power steering line on the rack. With a 302 block you should have more clearance. My pan is about a little more than 1/4" away from my rack. I think i enjoy the vibration. But its not so bad as long as you use a rubber/ urethane mount for the trans. I hear solid trans mounts have alot of vibration.
95cbr331
79
Port Orchard, WA
Mar 23, 2009
#11
  • Mar 23, 2009
  • #11
I agree the vibrations felt through my car were minimal, I only have 100 miles on the car since most the mods but i drove most those on I-5 and the ride was fine. Also
I felt more vibrations with brand new energy suspension poly mounts...im using a rubber tranny mount now though.
ProKiller
3,064
15
78
PA
Mar 23, 2009
#12
  • Mar 23, 2009
  • #12
seems the most common thing is to keep a rubber tranny mount and whatever you want for the motor mounts.
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
E
3.8l upgrade, motor mount options
  • Ed Russell
  • Nov 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 2, 2025
Ed Russell
E
D
Resolved Vortech hitting hood
  • Dchichizola
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
General karthief
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
