Solved my "Knocking" Dilemma
  • Thread starter Thread starter 1989MustangLX
  • Start date Start date Jun 27, 2005
1989MustangLX
118
Canada
Jun 27, 2005
  • Jun 27, 2005
Well, it was my own dumb fault. Rather than order the right bolt the first time, I decided to attach the pickup tube to the main cap by loosening the bolt, inserting the tab on the pickup, and then torquing the cap back down. Bad idea. Not only is the tab material soft, it also brings some clearance issues into play. Either the crank or connecting rod was hitting the tube, and took a nice chunk out. So how can I make sure I get most of this **** out of the engine after I get it back together? An oil change after it runs a bit?
Here's what the tube looks like:
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jun 27, 2005
  • Jun 27, 2005
Ooh,not good.Thats why I had to modify my pan pick-up,got to close to the rod bolts.
Looks like the rod bolt hit it and the holding tab ripped.Didnt damage anything else?
1989MustangLX
118
Canada
Jun 27, 2005
  • Jun 27, 2005
I notched the tab so that it would fit under the main bolt. It's my own fault that I didnt use the proper part. I can't check the rods or anything in the bottom end, as I havent got the lift anymore. I will be getting it back in a few days though. I called the dealership and ordered the new main bolt with the stud, and I ordered a chromoly oil pump driveshaft.
1989MustangLX
118
Canada
Jun 28, 2005
  • Jun 28, 2005
ttt
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
