Some nitrous questions.
  • Thread starter Thread starter Marlboro_Man
  • Start date Start date May 13, 2006
M
Marlboro_Man
437
Houston, TX
May 13, 2006
  • May 13, 2006
So i got a nitrous wet kit for my B-day. So far I've got everything setup except wiring the 12v to the fuel/n20 sylenoids and buying an msd window switch. I'm planning to start with a 50 shot and slowly work my way to a 100 when i'm comfortable with it.
My first question is: Do i need a relay for the fuel/n20 sylenoids or can i just use an inline fuse for them? If i can use a fuse what size?
Second question: I'm going to get some new plugs but not sure whether i should get autolite 23's or 24's??? I'm currently running 25's. I have an msd 6al and a blaster 3 coil, should i run a smaller or larger gap now with the n20?
Third question: The kit didn't come with a bracket for the micro switch (WOT) so do i need to buy one or just fab one up or is there another way to mount it? Where are you guys putting the switch at on our cars , by the throttle body or under the gas pedal?
Thanks ahead, I'll have more questions to come so please bear with me.
:SNSign:
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 13, 2006
  • May 13, 2006
1: You can use a inline fuse. I believe a 10 amp fuse will get you what you want.
2: For every 100hp shot of juice you want to step down to a colder plug. I use accel u-groove 784's. Also don't forget that for every 50hp shot of juice you need to take 2 degrees of timing out.
3: I run a carb but i have seen guys use the IAC bolt to mount the bracket for WOT micro switch. not under gas thats a bad idea. you could fab up something i'm sure.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 13, 2006
  • May 13, 2006
http://www.edelbrock.com/automotive_new/mc/nitrous_systems/access_switches.shtml
the universal bracket is in a picture if you scroll down the page to part number 72279.
M
Marlboro_Man
437
Houston, TX
May 13, 2006
  • May 13, 2006
Thanks!
So for the plugs i should only go one step colder right.
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 13, 2006
  • May 13, 2006
Yes you NEED a relay. You are supposed to put an inlien fuse in between the + wire from the relay to the + battery terminal.
Use autolite 24's gapped around .035"
Just rig up a bracket for the microswitch or buy a new one as they're dirt cheap.
M
Marlboro_Man
437
Houston, TX
May 13, 2006
  • May 13, 2006
Ok so if i need a relay then what kind do i need to buy? Can i get it at autozone or orielly?
I put in 24's and gapped them at .038, is that good?
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 13, 2006
  • May 13, 2006
Try and find a bosch 30/40a relay. But im sure any parts store relay will be ok. That gap should be fine since you aren't spraying a big shot.
RYC CUKR
1,437
Orlando
May 13, 2006
  • May 13, 2006
Here is how I have mine wired.
I feed 12v into an arming switch mounted where my ashtray used to be. From there I go to the WOT microswitch mounted on the TB, and then to my MSD window switch and finally to my relay. I really should get a low FP cut off switch and wire it in as well. The relay actuates both the nitrous and fuel solenoids and only is energized when the arming switch is on, RPM is between 3000-5800 and I am at WOT.
Most of the arming switches and other rocker style switches aren't intended to handle the amperage that the solenoids draw. The switch could fail and not work or even worse the contacts could actually weld closed and end up sparying nitrous into the engine after you run. Relays are cheap, engines aren't.
What type of kit did you get? It truly is alot of fun and somewhat addictive.
Enjoy the new toy.
M
Marlboro_Man
437
Houston, TX
May 14, 2006
  • May 14, 2006
Enjoy the new toy.
It's a "Cold Fusion" wet kit.
So all i need is the relay, rpm window switch, fuel safety switch and a microswitch bracket and then i can play with my new toy!
Another question: Is it safe to leave the nitrous bottle in the car during the day? Cause it gets pretty hot down here (90-95* lately) and the inside car temps can and will definatly go above 120*.
RYC CUKR
1,437
Orlando
May 14, 2006
#10
  • May 14, 2006
  • #10
I would take it out. I have mine in the trunk of my vert and I take it out unless I am going to the track. Florida is the same way, pretty darn not during the day.
Looks like you should be pretty good to go once you get the stuff you listed.
You'll enjoy it. I went from 14.00s to 12.7s with the 100 shot
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • dan50
  • Jul 18, 2026
dan50
