  • 1994 - 1995 Specific Tech
Something is hitting!!!
  • Thread starter Thread starter Guero
  • Start date Start date May 8, 2006
Guero
2,148
May 8, 2006
  • May 8, 2006
Ok so i i drive the beast(lol), and i pass arond 3500 rpm, something starts to hit, sounds like from the back of the driver side valve colver. Im thinking a rocker nut is coming loose, and is loose enough just to hit when i reach that rpm. Any thoughts from you guys? im gonna retorque the heads, since i have to take of the top intake to see into the valve covers, just wanted your 02 cents if im right.
jgfiveoh
102
Topeka, KS
May 8, 2006
  • May 8, 2006
is it hitting or rattling type sound?
jgfiveoh
102
Topeka, KS
May 8, 2006
  • May 8, 2006
is it hitting of rattling? jus wondered
Guero
2,148
May 8, 2006
  • May 8, 2006
a little of both mosttly hitting
Guero
2,148
May 8, 2006
  • May 8, 2006
any thoughts?
1TallMF
955
Montreal
May 8, 2006
  • May 8, 2006
I would think that if you had a loose rocker nut, you'd be hearing a loud clicking noise at idle as well, not only hitting at higher rpm's. Do you hear it if you put it in neutral and rev it, or is it only when the engine is under load, say when flooring it in third gear? Either way, I'm sure you'll find something out of whack when you take 'er apart
Guero
2,148
May 8, 2006
  • May 8, 2006
it doesn't do it it at idle, unless i just put it under load, then it does it under load then in idle for a few seconds. went to my friend who is an mechanic, and he said the oil might be tear it up sooner since it does it at higher rpm, he said i might need to which to 20 50,
Guero
2,148
May 8, 2006
  • May 8, 2006
But does the rocker travel its whole distance when just shifting below1700rpm? If it doesn't and travels the whole distance only when under load. maybe its just loose enough to where it hits the valve cover what else could it be? cant be the spring, valve or pushrod, cuz then i would hear it all the time.
1TallMF
955
Montreal
May 8, 2006
  • May 8, 2006
Something's got me thinking perhapse sufficient oil is not getting though one of the lifters, and hence to the pushrod and rocker arm. I'd try maybe a bottle of "oil flush", to get rid of any gunk that might be stuck in a lifter, then drain the oil and run something a bit thicker, maybe 10W40, or 20W50 if its REALLY bad, or even some of that Lucas stuff, seems to work quite well. Perhapse someone else will have a better idea of what might be causing it
Guero
2,148
May 8, 2006
#10
  • May 8, 2006
  • #10
there shouldn't be any gunk. new heads, rockers, lifters, and rods. maybe all of the anti freeze didn't come out???
1TallMF
955
Montreal
May 8, 2006
#11
  • May 8, 2006
  • #11
Okay, I wasn't sure if you had replaced the pushrods and lifters with the new cam. Maybe just pull the valve cover and retorque the rocker nuts and check for any play in the pushrods.
Guero
2,148
May 8, 2006
#12
  • May 8, 2006
  • #12
ill try 10 40. its still 5 qt, right even with with aftermarket heads?
1TallMF
955
Montreal
May 8, 2006
#13
  • May 8, 2006
  • #13
yup, still the same
chefster
426
michigan
May 8, 2006
#14
  • May 8, 2006
  • #14
sure its not spark knock?
Guero
2,148
May 8, 2006
#15
  • May 8, 2006
  • #15
huh?
1TallMF
955
Montreal
May 8, 2006
#16
  • May 8, 2006
  • #16
spark knock, also known as the dreaded "pinging"
Guero
2,148
May 8, 2006
#17
  • May 8, 2006
  • #17
its to loud to be pinging.
M
mackey
1,284
Beverly, Massachusetts
May 9, 2006
#18
  • May 9, 2006
  • #18
A heavier weight oil isn't going to fix the problem. It either sounds like an exhaust leak which isn't that bad so you only really hear it under load. It could be your pipe from head to head aswell. I'd search around with a vacuum tube for a leak first. If you are 100% sure it is a rocker/lifter or internal. DO NOT drive the car. Fix it first.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
SBF rebuild with no oil pressure NEED HELP
  • Falcon67
  • May 27, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2025
horse sence
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
