Something Popped!!
  • Thread starter Thread starter VT66PONY
  • Start date Start date Jun 11, 2005
1 of 2 Next Last
V
VT66PONY
38
Virginia
Jun 11, 2005
  • Jun 11, 2005
So I was on the highway today and something just popped. Now Back driver's side wheel has a knocking sound and it hops. Whats wrong? Something with the wheel bearing?
FasterThenU72
108
Orange County, CA
Jun 11, 2005
  • Jun 11, 2005
check the leaf springs.....i see it every day, the shackles bust apart, but you still seem on the road.....thats my guess anyways....
V
VT66PONY
38
Virginia
Jun 12, 2005
  • Jun 12, 2005
Well I checked the shackles and they are fine. I drove it this morning and the knocking sound is not as loud but you can definitely still hear it. I don't even know where to begin troubleshooting this.
FasterThenU72
108
Orange County, CA
Jun 12, 2005
  • Jun 12, 2005
ok then check the shock mounts and the shock itself.....that's about all i know of that will cause wheel hop....
notny41
204
Minnesota
Jun 12, 2005
  • Jun 12, 2005
Could chock the front wheels and jack up the drivers rear and turn the wheel around by hand and see if the noise is there.
iskwezm
4,159
20
79
Rowland Heights,California
Jun 13, 2005
  • Jun 13, 2005
did you lose a wheel weight?
V
VT66PONY
38
Virginia
Jun 13, 2005
  • Jun 13, 2005
I'm gonna try to jack it up after work tomorrow and see if it is the rear wheel making all that noise.
Where is the wheel weight?
I should probably clarify that it doesn't so much as hop but seems to slow the car down. The car staggers at low speeds. It probably does it at higher speeds but its not as noticeable.
1320stang
4,329
23
89
Edmond, Oklahoma
Jun 13, 2005
  • Jun 13, 2005
Might be a spring in the brake drum.
Wheel weight, you know, the lead weights they put on the edge of the rim to balance it?
84convertablegt
589
Columbus, OH
Jun 13, 2005
  • Jun 13, 2005
if its just draggin, id say something brake related. better not drive it until u figure it out. especially if its brakes or anything really for that matter. could be something in the rear end, but unlikely. sometimes a consistent knocking is a u joint, but you wouldnt have the lag id say. how do you know its just one wheel, can you hear it for sure from one side or something?
FasterThenU72
108
Orange County, CA
Jun 13, 2005
#10
  • Jun 13, 2005
  • #10
wait a minute i always thought that if you lose the u joint in any way shape or form, your gonna have a sick vibration all through the car......?
V
VT66PONY
38
Virginia
Jun 13, 2005
#11
  • Jun 13, 2005
  • #11
Ok, so today I jacked up the rear driver's side wheel to turn it and it only rotates about 1/8 rotation each way. After that, it doesn't want to rotate anymore. Isn't suppose to rotate 360? I'm about to take off the wheel and take a closer look but I wanted to see if anyone had any ideas? Thanks a lot.
84convertablegt
589
Columbus, OH
Jun 13, 2005
#12
  • Jun 13, 2005
  • #12
silly question, but is the car in neutral when you are trying to move the wheels?
also
Yes, im sure it could cause this, but on my old truck when the u joint started to go bad, it just made a clunking noise when you put the car in gear and got under any kind of load, there was no vibration, although i dont think that this is his problem, it was just an idear!
bnickel
5,640
lubbock, texas
Jun 13, 2005
#13
  • Jun 13, 2005
  • #13
sounds like a bad wheel bearing to me
yeloxr7
429
#14
  • Jun 13, 2005
  • #14
Maybe a brake spring or some other brake part broke inside the drum.
V
VT66PONY
38
Virginia
Jun 13, 2005
#15
  • Jun 13, 2005
  • #15
OOPS...that was not a silly question....so its in neutral and the wheel spins but its not making any kind of noise....and i haven't lost a u-joint. I dunno.
1320stang
4,329
23
89
Edmond, Oklahoma
Jun 13, 2005
#16
  • Jun 13, 2005
  • #16
You'll need to jack up both sides at the same time as it may be locked to the passenger side still. If it only turned an 1/8 of the way, you'd be dragging the tire until it went flat.
iskwezm
4,159
20
79
Jun 13, 2005
#17
  • Jun 13, 2005
  • #17
I think it was just in gear
V
VT66PONY
38
Virginia
Jun 13, 2005
#18
  • Jun 13, 2005
  • #18
Opinions on how this should look......
So I MIGHT have found the problem. Can someone tell me if the rearend is suppose to look like that? I don't think it is...
Rearend
Rearend 2
67efivert
348
lincolnton nc
Jun 13, 2005
#19
  • Jun 13, 2005
  • #19
not a good thing but is fairly common to old rear axles u need to at least check th fluid level though
bnickel
5,640
lubbock, texas
Jun 13, 2005
#20
  • Jun 13, 2005
  • #20
fluid seepage is not uncommon at all on a 35 year old car. jack the car up in the back and see if you can wiggle the wheel up and down if so you have a bad wheel bearing. had the same thing happen to my old 70 cougar and it had what you are describing with the wheel "hopping" it almost feels like you're driving on a flat tire huh?
1 of 2 Next Last
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
