Spark plug experts
  • Thread starter Thread starter Edbert
  • Start date Start date Apr 11, 2005
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
So, should I just buy whatever plugs the instruction manual for my heads (non-smog perf-rpm) say or do the various gurus and experts that hang out here have better recommendations?
My cam specs are in the sig as is my ignition, my cr is about 9.5:1, I intend to run 87 octane. Anything else that would effect the choice?
I'm going with the stock timing of the pro-billet distributor out of the box, any recomendations for a starting point on the gap?
rbohm
6,698
550
204
tucson,az
Apr 11, 2005
  • Apr 11, 2005
start with the heat range they recommend, then change as needed. you can use the the plug number they list and have the parts person cross reference the number to your favorite brand plug, it one exists.
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
I don't have the instructions with me right now, but I know they used a Champion part for their recommended plug. I always used Autolites back when i was daily-driving a classic stang, but I stopped doing that in 1992. I know the platinums are good, but until i get my plugs heat range and gap figured out I don't think I should invest in platinums yet. Are those multiple tip plugs a marketing gimick?
jerry S
1,365
52.22N 5.12E
Apr 11, 2005
  • Apr 11, 2005
I have your same heads. I corresponded with edelbrock tech on the matter and they said I am best off sticking with Champion RC12YC or equivalent. The guy who built my car said I couldn't do better than the Auotlite 3924 plugs.
rbohm
6,698
550
204
tucson,az
Apr 11, 2005
  • Apr 11, 2005
edbert, if you are refering to the splitfire plugs, or the bosch plugs that have multiple electrodes, i personally think they are not worth 6$ per plug.
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
Thanks guys!
Do you know if those two choices correspond with one another on the chart?
Those are two of the type I was refering to. I can see if your spark it a little weak that might help but my spark should be about as hot as it can take with the full MSD arrangement. I figured they were sort of a scam but wanted a back up opinion
jerry S
1,365
52.22N 5.12E
Apr 11, 2005
  • Apr 11, 2005
Yes. they are both gasket seat, 5/8 hex, 14 mm, 3/4 reach plugs.
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
EEEEEWWWWWWW...milimeters!! *&#*^%#@
just kidding, thanks jerry!
HistoricMustang
2,359
Confederate States of America
Apr 11, 2005
  • Apr 11, 2005
I have had good success with the Bosch plugs and would suggest starting with .035 and working up. This deal is kind of like cutting front coil springs..............it is a pain in the butt but well worth the effort.
HistoricMustang
www.historicmustang.com
thehueypilot
1,084
Medina,Tennessee
Apr 11, 2005
#10
  • Apr 11, 2005
  • #10
I found an excellent web site for crossing plugs from hot to cold and Autolite to NGK ect. Its safer than relying on the parts counter kids from giving me the wrong plug. Its called Sparkplugs.com
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
Other Auto Tech Jun 24, 2024
Wallyman
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
H
'86 New Turbo Build First Start/Idle Trouble. Full Tune specs attached
  • Heffay
  • Jul 10, 2022
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Jul 12, 2022
Heffay
H
