  • 1994 - 1995 Specific Tech
spark plug gap on a 10:1 compression engine
  • Thread starter Thread starter twstd50
  • Start date Start date Sep 28, 2004
T
twstd50
97
  • Sep 28, 2004
I'm having a misfire at around 6100 rpms and I think my spark plug gaps may be wrong. What should they be gapped to on a 331 stroker with 10:1 compression?
Thanks...
HISSIN50
34
129
Sep 28, 2004
  • Sep 28, 2004
what ignition set up do you have (and how old are the components)? and you are not hitting a limiter, right?
if you think your flame is being snuffed out, have you closed up the gap a bit.
much like timing, im not sure you will find one magic gap that fits all (folks with similar set ups). you will likely have to play with it and close it up till you are not running out of spark.
my two cents. good luck.
Joes95GT
3,132
Delaware
Sep 28, 2004
  • Sep 28, 2004
If you've got an MSD ignition, you could probably run close to .060.
Like mentioned, close the gaps to about .035 or .040 and see what happens. If it works fine, you know you were running too much of a gap, however I don't think that's what your problem is.
Joe
T
twstd50
97
  • Sep 28, 2004
Thanks for the advice guys...
I've got a Crane Hi-6 ignition and coil. I'm pretty sure I'm not hitting the rev limiter as it's really sporatic.
HISSIN50
34
129
Sep 28, 2004
  • Sep 28, 2004
Joe has some nice advice for you. i might try gapping the plugs pretty tight (so as to rule out their being snuffed out). if you still have issues, to me, that sounds like your TFI might not be up to snuff at higher RPM's. we dont have a lot of info from you to guess from, but i would not overlook the TFI (or atleast consider it).
good luck.
T
twstd50
97
  • Sep 29, 2004
Please refresh my memory...what is the TFI and what does it do?
Thank you,
Tony
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
