Spark plug gap size question...
  • Thread starter Thread starter BLADDER92FOX
  • Start date Start date Oct 13, 2005
BLADDER92FOX
153
Miami
Oct 13, 2005
  • Oct 13, 2005
I was wondering about gap size do i set my plugs at for my 92 mustang 5.0 liter. I will be doing it myself for the first time pretty soon, also i heard there are diferrent tools to do it with and which ones better?
notchback
1,950
St Clair Shores MI
Oct 13, 2005
  • Oct 13, 2005
.053" is stock...but use about .045
keeps a tighter spark i like it better
if you have an msd6a, coil and msd dizzy then go w/ bigger
The Shape
2,224
East ARKANSAS Delta
Oct 13, 2005
  • Oct 13, 2005
I have alwasy just used the stock .054 as the gap. As far as special tools just a regular gap gauge and a basic socket set will do it. Only plug hard to get to is the number 4 wich is the very back on the passenger side if you still have your smog system in place. And even then it isn't that bad. Oh and no need to waste money on expensive plugs plain old Autolite 25's work great.
BLADDER92FOX
153
Miami
Oct 13, 2005
  • Oct 13, 2005
I'm using motorcraft plugs,thats all my cars had after i switched and it runs well. Anyways i'll just ask my mech from the speed shop what he gapped them to when i buy them there today. Thanx.
Mavrick
2,264
Collingwood, ON
Oct 13, 2005
  • Oct 13, 2005
Use the stock gap of .054"
Carney Woods
191
Montreal, Quebec
Oct 13, 2005
  • Oct 13, 2005
I gap mine at .48 with ford plugs.
jackchan
507
Mobile Alabama
Oct 13, 2005
  • Oct 13, 2005
spark plug gap I set according to how its ran. IF NA you can run a stock gap but if you use a hotter ignition, run it a little hotter plug with a little wider gap, for better power.
if running nitrous u need a colder range plug, and closer gap, the nitrous will "put out" the fire if the gap is too wide.
Jack
HISSIN50
34
129
Oct 13, 2005
  • Oct 13, 2005
I do like some of these guys and run a slightly tighter than stock gap (around .045-048) to allow for an old ignition and gap erosion over time.
25's are my choice as well.
If you have a quality ratchet (which requires little movement before it clicks - good for tight spaces), a short and long wobble extension, an air tool (ball in socket) universal swivel joint, and perhaps some spare fuel line, you should be all set.
I like to neverseize the threads. Copper neverseize conducts a little better than alum, but alum is common and works fine.
Good luck.
BLADDER92FOX
153
Miami
Oct 14, 2005
  • Oct 14, 2005
I pulled out one of my plugs and checked it today and it should have another few months left in it. I'll check in January again and see. All is well..
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
