spark plug issue
  • Thread starter Thread starter 302mustanglx
  • Start date Start date Oct 24, 2010
302mustanglx
41
mesquite nv
Oct 24, 2010
  • Oct 24, 2010
hi there one again guys im having a problem with my plugs.they seem 2 be faulin out and im forse 2 get new ones every tree weeks or so. im gaping them at 54. fuel is there timing is at stock 10.The mods that i have are alumenum pullys no smog what so ever intake,fuel reg,uper and lower intake,70m trottle body and spacer,headers,hpipe,full exhaust,alumenum raydiator,short shifter,373s,control arms,dragracing springs,short shifter msd wires coil cap.the plugs that im using are motocraft not the coper ones this have become a issue because this problem.I have a nitrous kit wet to be installed.Im just wating 2 get it running right. i dont know if i shoul close the cap to like a 45. or what do u guys think.
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Oct 24, 2010
  • Oct 24, 2010
Did you run the codes yet?
Doing a little spell check and proper use of punctuation/capital letters also makes your posts easier to read and understand. Doesn't have to read like a novel, it's just how your wrote it, it's hard on the eyes.
DucatiRdr
271
North of Boston, Massachusetts
Oct 24, 2010
  • Oct 24, 2010
Holy understatement of the year. I normally just chuckle at bad spelling/grammer but this post takes the cake.
87_LX_5.0
142
23
29
Uniontown, PA
Oct 24, 2010
  • Oct 24, 2010
HISSIN50
34
129
Oct 25, 2010
  • Oct 25, 2010
Try copper plugs for now.
G
gearhead101
23
lakeland,florida
Oct 25, 2010
  • Oct 25, 2010
i would do a compression test and see where your at. if your low on compression then that letting oil get past the rings and kill the plug. also does your car smoke at idle then clear up went you give it gas? if so this is a clear sign of oil seeping by your valve guide seals and if its really bad this will also kill your plug. if all that turns out to be good check your fuel pressure at idle it should be around 35psi. if that passes the test check your coil voltage not the power wire but the voltage going to the coil post. and also check the cap rotor for wear and build-up. hope this is some help.
G
gearhead101
23
lakeland,florida
Oct 25, 2010
  • Oct 25, 2010
by the way what color is the plug when pull them out white brown black wet dry etc.
302mustanglx
41
mesquite nv
Oct 25, 2010
  • Oct 25, 2010
brown my fuel presure is at 40 psi at idle im turning it down 2day
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
R
2005 crank but wont start! have fuel and spark
  • ricky760
  • Feb 21, 2019
5K
2005 - 2014 S-197 Mustang -General/Talk- Feb 22, 2019
ricky760
R
Engine 1998 GT - Weird idle and misfire issues
  • bio4554
  • Jul 30, 2018
5K
SN95 4.6L Mustang Tech Aug 12, 2018
tirebytes
T
For Sale 2003 Cobra Redfire Convertible
  • SpectorV
  • Feb 20, 2019
5K
SN95 Mustangs For Sale (1994-04) Feb 20, 2019
SpectorV
