  • SN95 4.6L Mustang Tech
Spark Plug Problem
  • Thread starter Thread starter 97Vicious281
  • Start date Start date Aug 20, 2005
9
97Vicious281
35
Atlanta, GA
Aug 20, 2005
  • Aug 20, 2005
Aiight I changed my spark plugs about a month ago, and I went from about 280 miles to a tank to like 230. Not too good since gas prices sucks these days. Just wondering if there is like a chart to gap them correctly because I didnt like 52-54 gap but when I took the ones that were in it out they were at like 64. Just looking for some suggestions.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 20, 2005
  • Aug 20, 2005
What is the model year, milage, spark plug type you used, and any other helpful information you can provide?
9
97Vicious281
35
Atlanta, GA
Aug 20, 2005
  • Aug 20, 2005
97 GT Vert Auto, I used MOtorcraft Platinum plug, stock number 432. I talked to a guy that works at the ford dealership and he said if you use anything other than motorcraft splugs they're more likely to skip. I changed the plug wires and coil pacs as well.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 20, 2005
  • Aug 20, 2005
You made an ok plug choice, not the best but acceptable IMHO. I believe that you gapped them correctly. The mileage drop could be a coincidence and could actually indicate that you need to change your fuel filter. How many miles?
9
97Vicious281
35
Atlanta, GA
Aug 20, 2005
  • Aug 20, 2005
It's got about 83500. I just changed them at like 80k and I don't think they have ever been changed before. I was hopin to get better gas mileage but that's not the case.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 20, 2005
  • Aug 20, 2005
Do the fuel filter for sure. Also, never hurts to reset the computer...
9
97Vicious281
35
Atlanta, GA
Aug 20, 2005
  • Aug 20, 2005
How do you reset the computer cause I know there is a button in the trunk behind the trim that says something about if the car doesnt crank or has problems with something to press the reset button and read the manual.
Hammer1999Gt
169
Toledo, OH
Aug 20, 2005
  • Aug 20, 2005
That reset button is for the fuel pump emergency cut off. If you are in an accident the fuel pump is shut off and you have to push that button to reset it. TO reset my computer I just disconnect the battery and let it set a couple minutes then reconnect it. Then there is a procedure in the owners manual to relearn the idle.
04GT
284
Southwest Ohio
Aug 21, 2005
  • Aug 21, 2005
Don't need to totally disconnect the battery to reset computer. Just take off the negative battery cable for a few minutes.
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Aug 21, 2005
#10
  • Aug 21, 2005
  • #10
Another thing that wouldn't hurt is a fuel system flush. Get some seafoam, dump it in the gas tank at your next fill up, and be sure to do as Kilgore trout instructed and change that fuel filter.
CanadaStang
2,093
Mb
Aug 21, 2005
#11
  • Aug 21, 2005
  • #11
Don't forget the air filter if you haven't checked it for awhile.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
