Spark Plug Question
I got some plugs and wires from LMR.
Plugs: Motorcraft: SP- 406, AGSP32C
Wires: FRPP 9mm
Question what should the Gap be? I saw the table that shows gaps but these plugs weren't on there. I
don't know the timing, or how to check. Mods are in the siggy. Thanks for the help guys.
stock gap should be fine for you
From "The Official Ford Mustang 5.0 Technical Reference & Performance Handbook 1979-1993" Ford Racing Part No. M-1832-Z4
Page 274
"Spark Plug Applications" table
Year---------Engine--------------Motorcraft number-------Gap (inches)
1979---------5.0L (49 state)-----ASF-52------------------.050
1979---------5.0L (california)-----ASF-52-6---------------.060
1980---------4.2L (all)-----------ASF-42------------------.050
1981---------4.2L (all)-----------ASF-52------------------.050
1982---------4.2L (all)-----------ASF-52------------------.050
1982-1985---5.0L carbureted-----ASF-42------------------.044
1982-1985---5.0L CFI------------ASF-52------------------.050
1986--------5.0L H.O.------------ASF-34 or 44------------.050
1987-1993---5.0L H.O.-----------ASF-42------------------.044
1993--------5.0L GT-40 (Cobra)--AWSF-42C---------------.050
1. Factory electrode gap specifications are shown on each Mustang's VECI label that is affixed underhood. The relatively wide gaps specified created the fat, long-duration spark needed to ignite the lean mixtures prescribed for most normal operating conditions.
2. Most non-Cobra 5-liter motors typically run well with spark plugs gapped at .052 inch. For normally aspirated engines in high-performance service, a plug gap between .040-.045 inch is suggested by many tuners. Those same sources also suggest .028-.034 inch in turbocharged, supercharged, and nitrous-fed five-ohs.
I plug the tester in power it up and then start the car. the manual has more details on how to extract more info such as the cylinder balance test. you have to press the gas to floor when the reader starts to flash or all testing stops and the reader cycles down.
If you try to plug in after the car is running it wont pull any codes, or at least I've never been able to.
I just ordered one of those digital code readers from Amazon for future use.
On the question of spark plug gap, I'm running Autolite #25's. The label under the hood on my '92 says 52-56 for the gap. I set my plugs at 54.
Should I pull them back out and re-gap to 44 instead?
The 54 is the recommended gap from the factory. You should be fine there but if you want tighten the gap to 44 and see if it impacts the performance. Equally important is what type plug you run.
Those heads call for a certain size and reach plugs - 14mm by 3/4". When I had E brock heads I ran the same plugs ( Autolite 3924's one step colder) gapped at 54.
http://www.framcatalog.com/Competitor.aspx?b=A&pn=AGSP32C&em=True
http://www.edelbrock.com/automotive_new/mc/cylheads/ford/sb_perf_rpm.shtml
Why blow $25 on a code reader that only works with old Ford EEC-IV systems when you can pull codes and run self-tests with a scrap piece of wire and a $0.99 12v test light? If you have a working CEL, then all it takes is the piece of wire.
Plug gap is more reliant on the ignition system and induction than the plug itself. I would use the stock gap with a stock TFI ignition and no power adders or high compression.
I dont have a CEL, i tried.
I have a habit of blowing $25 on all kinds of things. I see your point though. I used to get the codes from my old GM OBD1 cars with a paperclip in the diagnostic port and count the CEL flashes.
