  • SN95 4.6L Mustang Tech
Spark plugs
  • Thread starter Thread starter blue46gt
  • Start date Start date Nov 7, 2004
blue46gt
53
WA
Nov 7, 2004
  • Nov 7, 2004
This is probably a dumb question but a guy I know was telling me that I need to run a cooler set of spark plugs in my car with the mods I have. Is this true?
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Nov 7, 2004
  • Nov 7, 2004
You do not "need" them, but a step or two colder wouldn't hurt anything either. I'm running a two step colder copper plug in my car now with no problems. I guess the decision is going to be yours. The advantage to a colder plug is less resistance to electrical charge, however, its not a "must have" for a n/a vehicle without high compression like the modular 4.6ltrs.
blue46gt
53
WA
Nov 7, 2004
  • Nov 7, 2004
Thanks for the response! What plugs would you suggest I use? Probably need to change them anyway.
T
TrevX
76
Texas
Nov 7, 2004
  • Nov 7, 2004
a 2000 GT doesn't have spark plugs....it has fuel injectors...and they are expensive too...someone told me around like 40-50 bucks a piece..and you need 8....
40th GT
916
Lawrenceville, GA
Nov 7, 2004
  • Nov 7, 2004
You're kidding right? If a 4-stroke gasoline engine doesn't have spark plugs, how is it going to complete the power stroke??
twogts4us
4,188
12
79
Dunedin, FL
Nov 7, 2004
  • Nov 7, 2004
Please sell your car immediately and go back to your bicycle.
And, while you're at it, sell all your tools, because you'd be dangerous trying to use them.
This is one of the worst tech posts I've ever seen.
twogts4us
4,188
12
79
Dunedin, FL
Nov 7, 2004
  • Nov 7, 2004
He must have one of those 4.6L diesel engines...!!!
blue46gt
53
WA
Nov 7, 2004
  • Nov 7, 2004
I didn't want to be mean but what the crap!
onesticker
222
Jacksonville,FL
Nov 7, 2004
  • Nov 7, 2004
edit: Sorry I thought you were the guy that said the GT has no sparkplugs. I would run a cooler plug with your set-up
blue46gt
53
WA
Nov 7, 2004
#10
  • Nov 7, 2004
  • #10
It's cool. What plug would you suggest I use with my setup?
onesticker
222
Jacksonville,FL
Nov 7, 2004
#11
  • Nov 7, 2004
  • #11
I'll have to do some reserch and get back to you tommorow. I'm running Motorcraft 12c's but that will not work for you. The heat range on these are close to the stock plugs.
CanadaStang
2,093
Mb
Nov 7, 2004
#12
  • Nov 7, 2004
  • #12
Motorcraft AGSF32PM [PM is for platinum]is the stock plug.
22 C [the C is for copper] and is 1 heat range colder
12 C is 2 heat ranges colder than stock.
You can also use the AWSF plugs.
CanadaStang
2,093
Mb
Nov 7, 2004
#13
  • Nov 7, 2004
  • #13
instangator
78
#14
  • Nov 8, 2004
  • #14
NGK TR6 and Autolite 103's are 1 step colder.
KJ Hoppus
1,008
Elk Grove CA
Nov 8, 2004
#15
  • Nov 8, 2004
  • #15
so a colder plug is better for a high compression motor?
BayArea02GT
44
Newark, CA
Nov 8, 2004
#16
  • Nov 8, 2004
  • #16
H
HIGDON
241
Ft. Hood, TX
Nov 8, 2004
#17
  • Nov 8, 2004
  • #17
Yes, they can help resist detonation buy helping keep heat soak in the combustion chamber down. Higer compression= higer combustion chamber pressures and temps(same as in s/c and nitrous, just on a lesser scale...) One heat range cooler for say a head-swapped car would be good. Now on a typical bolt on car a stock heat range plug will work just fine. . .it'll keep some of the heat in the combustion process in the chamber where it is needed;where as in high comp.,s/c, and nitrous a little too much extra heat is added due to higher cylinder pressures and needs to be "bled" off, hence the smaller insulation of the cooler plugs which allows heat to dissipate more rapidly. Wow. . .I need to stop drinking, it makes me a typing fool.
Oh yeah... Here are a few plugs that would work just fine for ya:
NGK TR6's
AL 103's
Denso IT20's
and the 22C's from Ford.
Black2001GT
1,267
Saints fan Stuck in FalCANTs country
Nov 8, 2004
#18
  • Nov 8, 2004
  • #18
I smell a CT.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Nov 8, 2004
#19
  • Nov 8, 2004
  • #19
I believe the kind I have are Motorcraft copper awf-sc12's. I could have a letter in there wrong, it's been a while. I know its two steps colder than stock though.
blue46gt
53
WA
Nov 8, 2004
#20
  • Nov 8, 2004
  • #20
Thanks for all the help everyone!! I think I'll go atleast 1 step cooler.
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
