  • SN95 4.6L Mustang Tech
special service message 15747
  • Thread starter Thread starter ocbaud
  • Start date Start date Jan 16, 2006
ocbaud
239
Midwest City, Oklahoma
Jan 16, 2006
  • Jan 16, 2006
A Mechanical Noise (Buzz, Growl, Scraping, Zip) May be heard on drive away after initial start-up.
Some 1992-2002 vehicles equipped with anti-lock brakes may exhibit a mechanical noise (Buzz/Growl) on drive away after initial start-up. Each time the vehicle is driven. As vehicle speed reaches approximately 11-32 KM/H (7-20 MPH). The anti-lock brake control module turns on the pump motor and valves for approximately one half second. At this time a mechanical noise (Buzz, Growl, Scraping, Zip) maybe heard. This is a normal function of the self-check by the anti-lock brake control module for additional information refer to workshop manual section 206-09.
anyone have any more info on this? my car has this problem and it kinda gets annoying. It not only makes the sound, but you feel the brake pedal pushing back at you when it does it along with the headlights dimming
sgarlic
3,085
Jan 16, 2006
  • Jan 16, 2006
What the message describes is normal. Sounds to me like you've got a weak battery or bad alternator as well.
My Jeep ZJ also states a similar thing (about the ABS self test thing) in the owners manual.
ocbaud
239
Jan 16, 2006
  • Jan 16, 2006
so when it makes the testing sound, its normal for the brake pedal to push back while pressing it?
wannabe2000GT
138
upstate, ny
Jan 16, 2006
  • Jan 16, 2006
mine does that sometimes at low speeds. i was also gonna say that my jeep says the same thing in the manual. id say its a pretty normal thing to happen since both my vehichels do it.
sgarlic
3,085
Jan 16, 2006
  • Jan 16, 2006
Depends I guess on what your defintion of normal is. Normal to me would be a momentary thing.. if it's doing it for several seconds, or affecting your braking real badly, then perhaps there's something else going on.
ocbaud
239
Jan 16, 2006
  • Jan 16, 2006
yeah, its momentary. just does it usually within the first 2 minutes of driving at very low speeds(coming to a stop)
this is my first car with abs, so maybe i'm just not used to it.
D
d90212
253
kailua, hawaii
Jan 16, 2006
  • Jan 16, 2006
Principles of Operation
The anti-lock brake system (ABS) module receives wheel speed readings from each wheel speed sensor and processes this information to determine if an ABS event is necessary. The wheel speed sensor electrically senses each tooth of the wheel speed sensor indicators as it passes through the wheel speed sensor's magnetic field.
The ABS module continuously monitors and compares the rotational speed of each wheel, and when it detects an impending wheel lock, modulates hydraulic brake pressure to the appropriate brake caliper. This is accomplished by the ABS module triggering the hydraulic control unit (HCU) to open and close the appropriate solenoid valves. Once the affected wheel returns to normal speed, the ABS module returns the solenoid valves to their normal position, and normal (base) braking resumes.
The ABS module is self-monitoring. When the ignition switch is turned to the RUN position, the ABS module will do a preliminary electrical check, and at approximately 12 km/h (8 mph) the pump motor is turned on for approximately one half-second. Any malfunction of the ABS will cause the ABS to shut off and the yellow ABS warning indicator to illuminate, however, normal power assisted braking remains.
The ABS module has the ability to store multiple DTCs in memory.
- why not read the service manual as well since you have the SSM
merc123
420
North GA
Jan 17, 2006
  • Jan 17, 2006
i've never heard this.
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • AmericanMuscle4.6GT
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
  • Locked
SOLD 91 Mustang 5.0 Lx Hatch A/t – Immaculate & Original $7k Obo
  • SDWitness
  • Oct 8, 2016
3K
Fox Body Mustangs For Sale (1979-93) Oct 21, 2016
SDWitness
I Have Had Enough With Ford!
  • GTA_V6_Mustang
  • Oct 15, 2014
6K
2005 - 2014 S-197 Mustang -General/Talk- Apr 10, 2015
BlackenedSVT
