Speedo Gear Question
  • Thread starter Thread starter Snikt89GT
  • Start date Start date Sep 16, 2006
Snikt89GT
264
Deland, Florida
Sep 16, 2006
  • Sep 16, 2006
I'm thinking about getting some 3.55s to replace the stock 3.08s but i'm unsure about the speedo. I have the following trans:
5-speed T5 (1989)8
E9ZR-7003-A
8 - This gearbox was introduced as a running 1989 upgrade. It has an 8-tooth speedo drive gear.
Looking at the Motorsport catalog, I don't see a speedo gear that lines up for 8T Drive gear and 3.55s, only goes up to 3.27s. What's the easiest way to fix this? Is it hard to just purchase a 7T drive gear and install it, then buy the 20 tooth speedo gear (black) which does line up to 3.55s?
Is there an easier way to fix that?
Thanks
Snikt89GT
264
Deland, Florida
Sep 18, 2006
  • Sep 18, 2006
Anyone know? How do you guys with late 89-93 T5s with 8T drive gears fix your speedo with a gear swap?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 18, 2006
  • Sep 18, 2006
The stock range of speedo gears work correctly with a limited range of tire sizes. The 23 tooth white gear works good for some guys, but self destructs in a few months for others.
See http://www.corral.net/tech/gearcalc.html for more help
Or
http://www.hanlonmotorsports.com/T5Speedo.asp
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 1%-3%. The drawback is that it isn't cheap.
Please excuse the typo (their's, not mine) in the following picture - it should read Custom ratio adapters, not Custom radio adapters.
See http://www.gaugeguys.com/ratioadapt.htm for more info.
JChalfan
551
Bellevue, WA
Sep 18, 2006
  • Sep 18, 2006
I have a '90 T5, though I don't know for sure how many teeth are on my drive gear. If 8 teeth is standard for a '90, that's what I've got!
I have 3.55's, and if memory serves, I have a 23 tooth white gear. My speedo is definitely close enough for me, I think it reads a little fast according to those "your speed is:" radar signs. I think it reads about 2-3mph fast when I'm going around 40.
If you really want it perfect, look into those deals jrichker is talking about.
And for the record, my speedo gear has been in about 9 months, and no problems yet.
Jeff
Snikt89GT
264
Deland, Florida
Sep 18, 2006
  • Sep 18, 2006
Jeff
That would be fine with me, 2-3mph off isn't bad. According to this http://www.mustanggt.org/gttranny.htm all 90-93s had the 8T drive gear. Maybe i'll just try that, I didn't want to make this more complex than it had to be.
JChalfan
551
Bellevue, WA
Sep 18, 2006
  • Sep 18, 2006
I'd just go with the 23 tooth and see how it works for you. You don't want to have to swap drive gears inside the trans if you don't need to.
Since the speedo reads a little fast, it'll make you less likely to get a ticket for cruising a few mph over the limit.
Jeff
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Sep 18, 2006
  • Sep 18, 2006
found this in the sticky
Manual Transmissions with 6 Tooth Drive Gear
Not found in OEM applications
Item Number
Description
N/A
3.08 Gear Ratio / Not possible
C0DZ-17271-A
3.27 Gear Ratio / Maroon 16 Speedo Gear
C3DZ-17271-C
3.55 Gear Ratio / White 17 Speedo Gear
C0DD-17271-B
3.73 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.90 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
4.10 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
4.30 Gear Ratio / Red 21 Speedo Gear
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Item Number
Description
C0DZ-17271-A
2.73 Gear Ratio / Maroon 16 Speedo Gear
C0DD-17271-B
3.08 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.27 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
3.55 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.73 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
Item Number
Description
C0DD-17271-B
2.73 Gear Ratio / Yellow 18 Speedo Gear
C1DZ-17271-A
3.08 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.27 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
3.55 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Item Number
Description
D0AZ-17271-A
2.73 Gear Ratio / Blue 16 Speedo Gear
C7AZ-17271-B
3.08 Gear Ratio / Gray 18 Speedo Gear
C7VY-17271-A
3.27 Gear Ratio / Tan 19 Speedo Gear
C8SZ-17271-B
3.55 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.73 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Item Number
Description
C7AZ-17271-B
2.73 Gear Ratio / Gray 18 Speedo Gear
C8SZ-17271-B
3.08 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.27 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Now if you really want to change the internal drive gear of your manual tranny you can match it according to the table below. Be aware that the 6 tooth will offer the most combos for numerically higher gear ratios and offer the greatest degree of accuracy. The 6 tooth gear selection table for a manual tranny is the first in the page.
Item Number
Description
E3ZZ-17285-B
6 Tooth Internal Drive Gear / Black
E3ZZ-17285-A
7 Tooth Internal Drive Gear / Yellow
F0ZZ-17285-A
8 Tooth Internal Drive Gear / Green
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
