just instaled 410s in my 93 vert. now speedo is off how do i calabrate it so im not reading 100mph at 65mph i know i need to change gears on speed cable is their a replacemet i can just buy thanks
get a 4.10 speedo gear from 5.0 resto.......if they dont have it, get the closest one, i have 3.90s so i had to get a 4.10 gear. The swap is a sinch...
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 1%-3%. The drawback is that it isn't cheap.
Please excuse the typo (their's, not mine) in the following picture - it should read Custom ratio adapters, not Custom radio adapters.
