speedo problems!
  • Thread starter Thread starter Foxfan88
  • Start date Start date Feb 11, 2007
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Feb 11, 2007
  • Feb 11, 2007
OK my speedo is crazy. when its cold outside in the winter. once the speedo gets past say.. 45 the speedo will jump to 80-115ish or so and jump around erratically. and while making a contant ringing sound. when its warm in the spring and summer it doesnt really do it at all.
i have noticed my speedo cable has burn marks on it and been cut up pretty bad. also it never did this until my t5 swap a long time ago.
also my speedo gear i sorta of chewed up but i put it in when i did my t5 swap so it was good starting out.
dont know if it could be the VSS or not.
my guesses are... worn cable with too many scrape and cuts( you can see the metal under te gray jacket) OR i routed it wrong when i did my t5 swap and it has too many bends. but i am still stumped as to why it only does it in cold weather. it has to be like under 40 degrees
give me your input.
modusmortis
54
  • Feb 11, 2007
i would say either speedo cable binding or the speedo head itself has gone bad. It sounds like you need to replace the cable anyways though. The VSS has nothing to do with the speedo, it provides input to the ECU.
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
  • dan50
  • Jul 18, 2026
dan50
